2210 vs. 54" rear blower
/ 2210 vs. 54" rear blower #1
foreman81
Bronze Member
JD 2210
2210 vs. 54\" rear blower
I ordered a 2210 last week with a 54" rear blower (forgot make) and was concerned weather it would be stable enough with fluid in tires and front weights only. I'm still waiting for delivery so I can't check. The dealer said that with the 210 loader there is no problem, however, I didn't want the loader. /forums/images/graemlins/blush.gif
So is it gonna bounce the front wheels off the ground with just the fluid and front weights or will be stable enough? I was looking at the curtis cabs (more weight) but the price is keeping me away for now. /forums/images/graemlins/frown.gif
/ 2210 vs. 54" rear blower #2
Re: 2210 vs. 54\" rear blower
What is the weight of the blower? the dealer should know that. How much weight on the front end?
/ 2210 vs. 54" rear blower #3
I think with the front weights, filled tires and your MMM you should be fine. Would like to see a picture of the blower attached if you can post..
j
/ 2210 vs. 54" rear blower #4
I've put 60" units on the back of BX's but they do have loaders on the front for leverage to offset the blower. The BX does have a shorter wheelbase then the 2210 and is physically smaller in length and width. With out knowing the amount of front weight, it makes this tough to answer but I would assume the dealer would be putting a full load of front weights on, and you should be ok.
/ 2210 vs. 54" rear blower #5
I've used a 500+ pound aerator on the back with 210 pounds of suitcase weights on the front and it was solid as a rock. My 2210 is very well balanced and ballasted for most loader work with a 325 pound box blade on the back when moving dirt, etc., with the 49" loader bucket.
Hope this helps.
</font><font color="blue" class="small">( What is the weight of the blower? the dealer should know that. How much weight on the front end? )</font>
I didn't ask him. I bought the thing in a hurry because I was pressed for time that day and I knew 2210s didn't last long on the lot. I believe it is around 350-450 pounds of weight. But if a 500 pound aerator wont budge it, I don't think the blower will.
I see alot of you fellas bought the loader. My initial impression on it was not very high after observing the frame and alluminum transaxles and limited capacity. I just assumed to step up to 4000s if I needed frequent loader use where I would get a tough package. Regardless, I bought an awesome tractor and I can't wait for it to arrive to bid my trusty 425 AWS goodbye and farewell.
Thanks for the replies!
/ 2210 vs. 54" rear blower #7
<font color="green">Even with its limited capacity on a 2210, I quickly learned how valuable a front end loader could be as a real back saver.
I often use it in place of a wagon or wheel barrow, setting the bucket to the right height for the task I need to accomplish.
Just yesterday I used it to move some firewood and some bricks. Even used it to knock over a couple of small, dead trees about 10 inches in diameter. The loader's height was sufficient to provide the leverage I needed. Granted the trees had been dead for several years and their roots had rotted so it wasn't surprising that they could be knocked over. I simply found it quicker giving the tree a push instead of cutting it with a chain saw and then still having to deal with the stump. The trees went over stump and all.
Mike </font>
/ 2210 vs. 54" rear blower #8
The 210 loader is surprisingly capable. I have moved a few dozen yards of soil, dug out stumps from several 13-16" diameter trunk trees, and lifted and carried its full limit which is something around 700 pounds at the pivot point at around 5 feet high. It's no toy loader for a small tractor.
/ 2210 vs. 54" rear blower #9
When I bought mine I really thought the FEL was going to be a joke. I have dug up 6" maple stumps, cleared sites, pushed brush, moved more rocks dirt etc includeing firewood. I thought when I bought it that the FEL would see very little use. It probably accounts for over 75% of my use. I think it does just about everything the 4010 series will do just a bit slower.No need for a snow blower here, The FEL works great for snow removeal. Dave
