2210 vs 4010 which is better? Any Common Problems with them?
   / 2210 vs 4010 which is better? Any Common Problems with them? #1
Anonymous Poster
Epic Contributor
HI All,
I have been looking for the past couple month for a tractor.
I have narrowed it down to just 4 models, but I think I will be ending up with one of these two tractors (2210 or 4010).
Any opinions on the 2210 vs 4010 in terms of with would be a better tractor?
I would be getting it with a MMM and a FEL.
Has anyone heard, seen, or experienced any common problems with the JD 2210 and 4010.
Thanks in Advance.
Fran
Subvet,
See my reply to your post under the general forum "Buying and Pricing".
It's just my $.02.
Bob
   / 2210 vs 4010 which is better? Any Common Problems with them? #3
I can not tell you to much about the 2210 but I can tell you that I am real satisfied with my 4010 (80 hrs) This machine has done plenty more for me than what I expected it to do! I did look at the the 2210 after I purchased my unit & thought that it looked more like an oversized garden tractor. Again, I can not say enough good things about my 4010! I have about 4 acres & have been using it to clear the majority of the trees off the land, move dirt, remove stumps & numerous other operations. I have used this machine extremely hard in the last 4 months, I have dented both fenders, had a tree fall on the hood (I bailed off or it would have got me) & broke both rear lights. This tractor has performed without a glitch! I will be happy to answer any specific questions you have! I do not think you will go wrong with any of the the tractors, after all they are both green! Good Luck!
   / 2210 vs 4010 which is better? Any Common Problems with them? #4
Re: 2210 vs 4010 which is better? Any Common Probl
SubVet ,
I have been happy with my 4110 410 FEL filled R4's with about 30hrs so far. I remember going into the dealer shortly after the 2210 came out , and for a few dollars more then the 2210 you could get into a 4010. Get the most tracotor for your money.
Good Luck ...
Mark
   / 2210 vs 4010 which is better? Any Common Problems with them? #5
I am also happy with my 4110, have a little over 20 hours on it now...
   / 2210 vs 4010 which is better? Any Common Problems with them? #6
Go with the biggest you can afford - the 4010!
   / 2210 vs 4010 which is better? Any Common Problems with them? #7
The J.D. 2210 has a bigger engine an more HP then the J.D 4010,
The physical size/weight between the tractors is close but the
2210 has smaller tires...
J.D 4110 is also similar in size but heavier with larger tires plus
a few extras...
J.D 4010, 47 cu.in., 18.5 eng. HP, 14 PTO HP @ 3000 RPM
J.D 2210 61 cu.in., 22.5 eng. HP, 18 PTO HP @ 3000 RPM.
J.D 4110 61 cu.in., 20 eng. HP, 17 PTO HP @ 2600 RPM
Done from memory which is not always 100% accurate...
Richard...
   / 2210 vs 4010 which is better? Any Common Problems with them? #8
I think the 4110 has 25 hp and 20 PTO
<font color=green>I think the 4110 has 25 hp and 20 PTO<font color=green>
<font color=black>In my JD Literature the 4110 is 20 hp @ 2650 rpm, 17 PTO hp & 61.02 cu. in.<font color=black>
   / 2210 vs 4010 which is better? Any Common Problems with them? #10
I was faced with the decision to get a used 4100 or a new 2210. Both about the same price. I went with the 2210 because of one word, warranty. Hp is all relative - you want to compare something, look at loader specs. The 4100 series will win, but the 2210 is a sweet little tractor that will move some serious material, I can assure you.
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
PALLET OF BAR LOCKS (A57192)
PALLET OF BAR...
CATERPILLAR D3G XL CRAWLER DOZER (A52707)
CATERPILLAR D3G XL...
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
