2210 top link plate leak - again
   / 2210 top link plate leak - again #1
mhalla
Bloomington, Indiana
John Deere 2210
<font color="green">Sorry to bring up an old topic that may be a painful reminder for some of you about the problem a number of us then new 2210 owners experienced when the first 2210's rolled off the assembly line and went into use.
I know there are now many more 2210 owners out here on TBN and since I haven't heard more about hydraulic fluid leaks around the top link plate I am thinking that maybe John Deere fixed the problem in later production runs.
What has been the experience of those of you who have bought 2210's in the past half year.
For those of you wondering where the leak occurs see http://www.tractorbynet.com/forumfiles/237505-hydleak01b.jpg for a picture previously posted by Bigpete. The leaking is from around the plate above where it says TUFF TORQ.
My 2210 is leaking again from what I saw the last time I used the tractor to remove snow from my driveway. It is not leaking as bad as before, a dull wet dirty appearance instead of the shiny oily appearance as before. That tells me it is a pretty slow leak.
Is a minimal amount of leakage something to expect around tractor transmission seals? I'm a bit reluctant to send the tractor back to have this problem fixed again and run the risk of a worse leak after the dealer's serviceman takes it apart and puts it back together.
Mike </font>
   / 2210 top link plate leak - again #2
I too am reluctant to have my 2210 serviced after 4 re-seals (the 4th a thin gasket and sealer). ... and it still seeps /forums/images/graemlins/mad.gif Not what I expected out of a <font color="green"> John Deere. </font> I will say the super service by my dealer eases the pain some. They picked-up and returned the tractor for each warranty service for free, and in most cases returned the tractor the same day /forums/images/graemlins/grin.gif
   / 2210 top link plate leak - again #3
I believe the correct fix for this problem is to replace the top link plate with a thicker one that will not flex. I have a later production model 2210 with the improved design plate and I have not had any problems.
Check with your dealer.
Ken /forums/images/graemlins/smile.gif
   / 2210 top link plate leak - again #4
I must be lucky, mine was fixed at 30 hrs (new sealant only) and I'm at 100 hours now with plenty of 3pt operation and not leaks....of course now I'm going to have to go out to the garage and take another look! Really unfortunate to have this recurring problem on an otherwise great little tractor.
   / 2210 top link plate leak - again #5
Stop it guys, you're scaring me! /forums/images/graemlins/shocked.gif I bought my 2210 in June. so far no leaks. I was shocked to learn here on TBN that the transaxle case is made of aluminum!! /forums/images/graemlins/shocked.gif makes me feel like I bought an overpriced plastic and aluminum toy.
   / 2210 top link plate leak - again #6
The tractor is a Yamar, just look at the gray market tractors, that's what kept me away from them. Made in Japan, not the USA! /forums/images/graemlins/confused.gif
   / 2210 top link plate leak - again #7
I don't think one can knock aluminum cases (nor be afraid of them) nor the fact some may be made in Japan. These small sizes of all brands are from 'around' the world and not "made in USA". I don't possess to understand the economics of this, but quality is determined by the manufacturer and makes the specs. As for an oversized toy, many of us agree on that but are happy with our "toy" /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
The mere size of some of these small CUTs and the power they have reflects on the need to keep the cost down and keep the weight down for lawn use.
Without abuse, these small CUTs will handle a lot of work. For problems, such as leaks (and the wrong design on hoses) Deere will likely take care of the repair within reason. Always have for me when needed. Nobody's perfect - yet. /forums/images/graemlins/wink.gif
   / 2210 top link plate leak - again #8
Did you get your hose problem fixed on your NH TC29? Early on as a new member you were discussing this problem, if I remember correctly. Just curious (not knocking blue here). /forums/images/graemlins/wink.gif
   / 2210 top link plate leak - again #9
the nh tc29d is shibaura which sells grey market also not made in usa .
   / 2210 top link plate leak - again #10
"The tractor is a Yamar"
I have never heard of a "Yamar" tractor. Is that the name of the company? /forums/images/graemlins/grin.gif
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
378713 (A51573)
378713 (A51573)
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2006 FORD F-250 (A52472)
2006 FORD F-250...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
