2210 top link plate leak - again
   / 2210 top link plate leak - again #1
mhalla
Bloomington, Indiana
John Deere 2210
<font color="green">Sorry to bring up an old topic that may be a painful reminder for some of you about the problem a number of us then new 2210 owners experienced when the first 2210's rolled off the assembly line and went into use.
I know there are now many more 2210 owners out here on TBN and since I haven't heard more about hydraulic fluid leaks around the top link plate I am thinking that maybe John Deere fixed the problem in later production runs.
What has been the experience of those of you who have bought 2210's in the past half year.
For those of you wondering where the leak occurs see http://www.tractorbynet.com/forumfiles/237505-hydleak01b.jpg for a picture previously posted by Bigpete. The leaking is from around the plate above where it says TUFF TORQ.
My 2210 is leaking again from what I saw the last time I used the tractor to remove snow from my driveway. It is not leaking as bad as before, a dull wet dirty appearance instead of the shiny oily appearance as before. That tells me it is a pretty slow leak.
Is a minimal amount of leakage something to expect around tractor transmission seals? I'm a bit reluctant to send the tractor back to have this problem fixed again and run the risk of a worse leak after the dealer's serviceman takes it apart and puts it back together.
Mike </font>
   / 2210 top link plate leak - again #2
I too am reluctant to have my 2210 serviced after 4 re-seals (the 4th a thin gasket and sealer). ... and it still seeps /forums/images/graemlins/mad.gif Not what I expected out of a <font color="green"> John Deere. </font> I will say the super service by my dealer eases the pain some. They picked-up and returned the tractor for each warranty service for free, and in most cases returned the tractor the same day /forums/images/graemlins/grin.gif
   / 2210 top link plate leak - again #3
I believe the correct fix for this problem is to replace the top link plate with a thicker one that will not flex. I have a later production model 2210 with the improved design plate and I have not had any problems.
Check with your dealer.
Ken /forums/images/graemlins/smile.gif
   / 2210 top link plate leak - again #4
I must be lucky, mine was fixed at 30 hrs (new sealant only) and I'm at 100 hours now with plenty of 3pt operation and not leaks....of course now I'm going to have to go out to the garage and take another look! Really unfortunate to have this recurring problem on an otherwise great little tractor.
   / 2210 top link plate leak - again #5
Stop it guys, you're scaring me! /forums/images/graemlins/shocked.gif I bought my 2210 in June. so far no leaks. I was shocked to learn here on TBN that the transaxle case is made of aluminum!! /forums/images/graemlins/shocked.gif makes me feel like I bought an overpriced plastic and aluminum toy.
   / 2210 top link plate leak - again #6
The tractor is a Yamar, just look at the gray market tractors, that's what kept me away from them. Made in Japan, not the USA! /forums/images/graemlins/confused.gif
   / 2210 top link plate leak - again #7
I don't think one can knock aluminum cases (nor be afraid of them) nor the fact some may be made in Japan. These small sizes of all brands are from 'around' the world and not "made in USA". I don't possess to understand the economics of this, but quality is determined by the manufacturer and makes the specs. As for an oversized toy, many of us agree on that but are happy with our "toy" /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
The mere size of some of these small CUTs and the power they have reflects on the need to keep the cost down and keep the weight down for lawn use.
Without abuse, these small CUTs will handle a lot of work. For problems, such as leaks (and the wrong design on hoses) Deere will likely take care of the repair within reason. Always have for me when needed. Nobody's perfect - yet. /forums/images/graemlins/wink.gif
   / 2210 top link plate leak - again #8
Did you get your hose problem fixed on your NH TC29? Early on as a new member you were discussing this problem, if I remember correctly. Just curious (not knocking blue here). /forums/images/graemlins/wink.gif
   / 2210 top link plate leak - again #9
the nh tc29d is shibaura which sells grey market also not made in usa .
   / 2210 top link plate leak - again #10
"The tractor is a Yamar"
I have never heard of a "Yamar" tractor. Is that the name of the company? /forums/images/graemlins/grin.gif
   / 2210 top link plate leak - again #11
Mhalla,
Sorry to hear about this problem, I've had my 2210 since the 1st of Augusta and have over 105 hours on her. No leaks so far, John Deere must have had engineering change since the first model. As far as built out of the country, any one that reads these forums on this web site (best so far) should know where their little toy is made. I'm proud of the decision I made and got all the information to do it off this site. /forums/images/graemlins/smile.gif
Hope you get her fixed. /forums/images/graemlins/smile.gif
Malvern
   / 2210 top link plate leak - again #12
Yanmar is a major tractor and diesel engine manufacturer in Japan. They make a high quality tractor and and one time completely built all of John Deere's compact tractors. Now they build the X90 series and supply engines for the 4X10 series. I believe they build the entire 4010 and the 2210 tractors. There is absolutely nothing wrong with a Yanmar tractor. Their tractors from the 1980's were as advanced and in some cases more advanced with more options than some of the new tractors offered in the USA now.
   / 2210 top link plate leak - again #13
/forums/images/graemlins/frown.gif
Mike, sorry to hear it is seeping again. I understand your hesitancy to send it back in. You should let your dealer know anyway and tell him just that. He may be able to extend the warranty for the case and any other related components. He might also be able to do better than that. Good luck----
   / 2210 top link plate leak - again #14
Mine started leaking at around 100hrs. I printed out the original thread from this site. I went to the JDparts site and printed out where the original link plate part number that was changed to a new part number. I also took pictrues of the new link plate that I found at another dealer, other than the one I purchased my tractor from. With all of this information I went to my JD dealer prepared for the worst. Was he suprised with what I showed him, so suprised he could not argue with me. He replace the link plate with the new one at no charge. Pick up and delivery no charge.
There is now 200hr and no signs of a leak, nock on wood...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
159118 (A60430)
159118 (A60430)
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
