(2210) solution for removal (small) oil/fuel filters/transmission filters,etc.
   / (2210) solution for removal (small) oil/fuel filters/transmission filters,etc. #1
Houkie
Denver, Colorado
John Deere 2210
Filters are sometimes hard to remove. Your fingers can't get to it, nor can you get or have a small wrench available that will fit around the area. Just look in your closet and take a regular belt with buckle. ( use the buckle for torque)
Belt is also handy for removal PVC pipe fittings and water ( well) filters. Hopefully this helps.
   / (2210) solution for removal (small) oil/fuel filters/transmission filters,etc. #2
They make and sell something pretty similar called a strap wrench.
For stubborn filters, I either use a pair of large channel locks, or drive a punch through the filter and twist. Never had a filter I couldnt get one of the two on. And since I dont even have an oil filter wrench, any filter that is beyone hand tight usually gets the channel locks.
   / (2210) solution for removal (small) oil/fuel filters/transmission filters,etc. #3
I have a band type filter removal tool.It has 4 different size bands and the handle can be moved to any position
making it easy to remove any filter.
Some folks don't live next to a store, order their parts and then o yeah, the filter/fitting doesn't want to move or you just can't get around it. A belt, now hanging in the garage helped me on several occasions.
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
Electric Concrete Mixer (A51573)
Electric Concrete...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
JOHN DEERE 7210R LOT NUMBER 263 (A53084)
JOHN DEERE 7210R...
