2210 smokes on startup
   / 2210 smokes on startup #51
Boy am I glad I logged on tonight!!! I didn't know this about the 2210 glow plugs. the dealer told me to turn the key to the ON position and wait 15 seconds. Though this will be the first winter for me and my 2210 this procedure has left me to conclude that the 2210 has no glow plugs. /forums/images/graemlins/confused.gifI couldn't find anything about it in the manual. I ran out just now and tried the tranny in gear and turn to START, the lights dim for about one second then a "click" and they get bright again. It is currently 50 degrees here, I can't wait till it get's cold again to try this. I have noticed -I had my dealer install an engine heater- that when I plug in the engine heater she starts real fast and clean. /forums/images/graemlins/cool.gif
On engine oil, I think diesels get their oil dirty quick no matter what based on my experiences. /forums/images/graemlins/tongue.gif
My 2210 has 90 hours. it never used any engine oil. /forums/images/graemlins/grin.gif
Oh, and um, sorry to break it to ya fellas, no such thing as "break-in" oil. That's just what they call the first oil fill in a new engine, it's the oil that's in it during break-in, REGULAR OIL. ask any dealer for "break-in" oil and they'll laugh at you.
   / 2210 smokes on startup #52
<font color="blue"> Oh, and um, sorry to break it to ya fellas, no such thing as "break-in" oil. That's just what they call the first oil fill in a new engine, it's the oil that's in it during break-in, REGULAR OIL. ask any dealer for "break-in" oil and they'll laugh at you </font>
Nobobody laughed at me when I bought my Break-in oil. /forums/images/graemlins/frown.gif
Pic attached. Text below directly from JD Parts catalog:
Break-in engine oil
A special-blend oil developed to be used in rebuilt or remanufactured engines and new John Deere engines during the break-in period. Identical to John Deere factory-fill break-in oil.
- The first 100 hours of operation is critical to the life and performance of an engine.
- During the first hours of operation, the rings and liners must seat (establish a pattern of surface mating) for proper performance. If this does not occur, the life of the engine can be adversely affected.
- High-quality premium engine oils should not be used as a break-in oil. The superior anti-wear characteristics of premium oils will inhibit the proper matching of components, which could result in excessive oil consumption
Illus. 92017
Applications
· Excellent oil for new or rebuilt non-John Deere engines. Engine rebuild instructions should be consulted to determine if special requirements are needed
Features
· Contains special additives to control piston ring and liner seating without scuffing
· These additives allow rings and liners to seat while protecting valve train and gears from wear
· Piston rings and liners establish a good wear pattern for maximum performance and extended engine life
Chemical and physical properties....
U.S.
TY22041
Break-in oil
1 gal.
6
TY22042
Break-in oil
55 gal.
1
TY22088
Break-in oil
5 gal.
1
Canada
TY22057
Break-in oil
4L
4
CXTY22088
Break-in oil
20L pail
1
Warranty: 90 days
Last modified: 27Jan03.
Dave,
I'm glad you mentioned that your plugs are only on for a couple seconds. That was my experience too. I was logging on to find out if mine were cutting out too quickly. BTW, I added some of the magic Power Service potion that was recommended here to my fuel, so I'll see if there is any improvements after adding it. Lots of good information here.
I'm going to try to do the 50 hour service this weekend if the weather isnt too bad.
Kurt
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2019 International HX620 T/A Wet Kit Day Cab Truck Tractor (A55973)
2019 International...
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
