2210 seat
/ 2210 seat #1
Bulldog160
WNY
JD 2210
Can anybody tell me how you hook up the switch underneath a 2210 when converting to a X-series seat? I see the actual seat hooks up the same but the switch housing is completely different.
/ 2210 seat #2
I know that this is an answer to your question but I just used the 2210 seat with the X series suspension.
/ 2210 seat #3
Really.....hmmmmmm
I think changing to the X seat helped more than the suspension did. I love them both, but you'd really benefit from changing that park-bench seat!
I left the switches OFF, so i can run it without being on it. :cool:
/ 2210 seat
Deadman said:
Really.....hmmmmmm
So if I don't plug it into anything it'll still run? Or do I have to jump it?
/ 2210 seat #5
The new seat should come with a switch just for that type of seat. When I did the suspension seat conversion I was wondering about that ,but when it came in it had its own switch. So it was a no brainer for me.
Jim
/ 2210 seat
The one I'm looking at is just the seat, nothing else. It's brand new but no hardware, safety switch, or suspension. I can get it for just under $100 shipped. But if I can't use it then what's the sense, right?
/ 2210 seat #7
I swapped the X series seat and suspension onto my 2210 and I'm pretty sure the new seat had the sensor in it. The sensor has a different shape but the connector is the same
I posted comparison / before and after pictures in the TBN picture gallery, if you do a search on "2210 seat" you will find them.
Of all the upgrades I've made to my 2210, the seat swap has provided the most benefit. If I was only doing one or the other I would do the suspension first then the seat......
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2020 John Deere 6120M (A62180)
2020 John Deere...
