2210 needs more light
   / 2210 needs more light #11
<font color="red">
Shouldn't the alternator/battery discharge light come on if the alternator isn't keeping up? I added one rear light to my 335GT and the charge light DOES come on with the lights and PTO engaged if I'm not running full RPMS.
</font>
Well I suppose that would depend on how it is wired and what it is measuring. You are assuming it is measuring some component of amperage draw. I have no idea about your GT and if it is measuring something different or set to a different level than the 2210.
All I know is what was posted. In simple terms: 20amp alternator means a maximum of 20amps going into the battery to recharge it. 25amps of draw means 5 more amps coming out than going in. Simply put, the battery is draining. Now I'm not an electrical guy. Maybe Soundguy or one of the other electrcial gurus on TBN can jump in and talk in more detail about this.
<font color="red">
I have 5, 55-watt lights on my 2210 and the discharge light has never lit up. So either I'm pulling just under 20 amps, the alternator is a little hotter than spec, or else the gauge just flat-out doesn't tell me what's really going on? </font>
Or it is not measuring any of those things, it is simply going to light up when the battery is drained down to a critical point. Afterall it is a discharge light. That doesn't mean it is in the process of discharging. It might mean "HEY, YOU JUST DISCHARGED TOO FAR, NOW YOU'RE IN TROUBLE." Just a thought?
   / 2210 needs more light #12
The charge light will come on when the battery reaches a low level like 10-11 volts. My S-10 does this when I run my Fisher plow too much with the truck idleing. When the volts reach 10 the light comes on. I would think your tractor would be close to that also. The battery light will come on if you wired the lights up between the alternator and battery. That is if the lights draw more amps than than alternator puts out. This would be a real no no.
   / 2210 needs more light #13
This is probably a stupid question, but, can the alternator be exchanged for one with higher output?
   / 2210 needs more light #14
Not a dumb question, yes you can take out the alternator and replace it with a larger unit. Heck, if I can do it then for sure you can do it. And to get me to understand even very simple stuff the lovely Mrs_Bob has to yell at me!
2012 PROCO KILL TRAILER (A58214)
2012 PROCO KILL...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
