2210 500 hour injector inspection?????
   / 2210 500 hour injector inspection????? #1
megotatractor
New Richland, Minnesota
JD 2210
The maintenance schedule says that at 500 hours we are due to adjust valve lash (I have studied the procedure and plan to do this myself) and "inspect fuel injectors"? I'm not a diesel mechanic but what is there to "inspect" about an injector? Are they talking eyeball inspection or some kind of measurement of it's performance on some kind of injector cleaning machine? Are diesel fuel injectors required to actually be replaced at some point ever so often?? I would think as long as the machine starts, runs smoothly, doesn't smoke, the injectors are working? I add a little injector cleaner to the fuel occasionally. As I approach 500 hours- now at 440 hours- I notice a little more black smoke sometimes.
   / 2210 500 hour injector inspection????? #2
They are talking about spray pattern and pop-off pressure. I would not worry about it until it run rough...
That's about what I thought. I was just mowing some very heavy grass tonight and thinking she's running stronger than she ever has, that occasional puff of black smoke is just saying she's working hard.
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2019 DODGE RAM 5500 HD SERVICE TRUCK (A54756)
2019 DODGE RAM...
197711 (A51244)
197711 (A51244)
2025 JMR 36in Mini Skid Steer Bucket (A55787)
2025 JMR 36in Mini...
2012 JOHN DEERE 310K BACKHOE (A51406)
2012 JOHN DEERE...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
