2210 500 hour injector inspection?????
   / 2210 500 hour injector inspection????? #1
megotatractor
Veteran Member
New Richland, Minnesota
JD 2210
The maintenance schedule says that at 500 hours we are due to adjust valve lash (I have studied the procedure and plan to do this myself) and "inspect fuel injectors"? I'm not a diesel mechanic but what is there to "inspect" about an injector? Are they talking eyeball inspection or some kind of measurement of it's performance on some kind of injector cleaning machine? Are diesel fuel injectors required to actually be replaced at some point ever so often?? I would think as long as the machine starts, runs smoothly, doesn't smoke, the injectors are working? I add a little injector cleaner to the fuel occasionally. As I approach 500 hours- now at 440 hours- I notice a little more black smoke sometimes.
   / 2210 500 hour injector inspection????? #2
They are talking about spray pattern and pop-off pressure. I would not worry about it until it run rough...
That's about what I thought. I was just mowing some very heavy grass tonight and thinking she's running stronger than she ever has, that occasional puff of black smoke is just saying she's working hard.
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2008 Ford Ambulance (A47477)
2008 Ford...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
