22 Hp Robin Engine
   / 22 Hp Robin Engine #1
Schultz
Dexter, MI
BX-2200
I noticed in my latest Northern Tool Catalog they are carring a full line of Robin/Suburu engines including the 22hp v-twin at a cost of $1,299.
Robin 22hp
   / 22 Hp Robin Engine #2
The item pictured has the shaft on one end only. Doesn't PT mount pumps on both ends of the engine?
   / 22 Hp Robin Engine #3
See taht plastic grill? Look at the shaft stub behind it. Cut a hole in the grill or remove it altogether. Now you have a shaft on each side of the motor.
Same thing for the Kohler.
   / 22 Hp Robin Engine #4
The current Kohler and Robin engines do not exactly use a stub shaft on the flywheel side.
The engine side of the lovejoy style connector bolts directly to the flywheel with the flywheel bolts and uses the end of the shaft for the flywheel as a pilot to center the Lovejoy style connector.
The older Kohler motors did use a stub shaft on the flywheel. I do not know at what serial number the change was made to mounting the Lovejoy connector directly to the flywheel. If anyone needs the old Kohler stub shaft, I have one taking up space in the garage.
bullitt
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
