2185 Pto Clutch Bearings
   / 2185 Pto Clutch Bearings #1
jgrinn
One of my bearings is going bad on my Pto clutch. I was going to replace them both, but can only find the one (luckily the one thats bad). Has anyone found a place that you can get both??? I'm just going to repack the other for now. Of course dealer tried to tell me I needed a new clutch $300.
   / 2185 Pto Clutch Bearings #2
most bearings have an identification number engraved on one side or the other of the component ... If yours has such, use that number to either do a internet google search or get it to a local retail outlet that sells bearings. you may be able to match them up and then get both bearings replaced while you're in there....
   / 2185 Pto Clutch Bearings #3
Check EBay you can get a new PTO cheaper than $300 on there.
   / 2185 Pto Clutch Bearings #4
I had to replace my pto. Hope you can fix yours but I am not sure you can. I was told they are not serviceable.
Michael
The bearings can be replaced. The dealer will not tell you that.
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
