2165 Running rough and blowing black smoke
   / 2165 Running rough and blowing black smoke #1
Wanavet
Cub Cadet/2165
My 2165 just started running rough after the last time that I mowed and is blowing black smoke. If I remove the air cleaner it seems to clear up. Will a new air filter fix the problem?
   / 2165 Running rough and blowing black smoke #2
That would be where I would start, does the air cleaner look dirty?
The pre-filter was fairly dirty but the air filter itself didn't look all that bad. When I removed the metal top off of the air cleaner while it was running there was quite a bit of suction holding it down.
   / 2165 Running rough and blowing black smoke #4
Just replace both the filters and see what happens.
   / 2165 Running rough and blowing black smoke #5
If it clears up with removing the air filter, i'd say it's a dirty air filter. It doesn't always look really dirty when an air filter is plugged. It's a cheap test anyway.
Not that cheap of a test!!! Just picked up a filter and it was over $19.00 /forums/images/graemlins/frown.gif
   / 2165 Running rough and blowing black smoke #7
Check NAPA or Carquest next time for an aftermarket air filter. eBay has good deals as well. You can shop-vac the pre and main filter to clean them up as well, but you should replace them per the manual. $19 for that filter is absolutely rediculous!
G/luck
Joel
Even though it wasn't cheap for the Briggs filter it worked running well. I had to replace the plugs as well due to them being fouled.
   / 2165 Running rough and blowing black smoke #9
Same exact problem I had with mine (hence the $200 deal). Turns out the filter was getting soaked with oil from the breather hose in the airbox due to a bad reed valve in the breather "block" itself. The filter was brand new, but it had become soaked with oil from the extra blowby getting by the bad reed valve.
Currently I rigged a hose to vent the breather outside of the airbox and have had no problems since while waiting for a new breather assembly.
Not sure if it's the same as your problem, but has the same symptoms (runs rich with aircleaner installed, runs fine without).
Best of luck.
   / 2165 Running rough and blowing black smoke #10
</font><font color="blue" class="small">( Not that cheap of a test!!! Just picked up a filter and it was over $19.00 /forums/images/graemlins/frown.gif )</font>
I thought it was cheap as compared to bringing it into a dealer to have repaired. Just thought i'd give you something to try before having a dealer or repair shop work on it.
/forums/images/graemlins/tongue.gif
2022 Padget Morris Electric Mobility Scooter (A55853)
2022 Padget Morris...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
