2165 hydrostatic prob
/ 2165 hydrostatic prob #1
mdrelyea
I just changed the hydrostatic filter on my 2165. When I changed the filter, I also changed the hydrostatic oil (I didn't have a clean container large enough to hold all 7 qts of the old oil, so I opted not to keep it). I got the tractor at an auction a few years back and it didn't come with a manual. A friend of mine also has a 2165, so I made a copy of his manual. It calls for "Cub Cadet Drive System Oil" part number 737-3055 or specifies a 20W50 oil that meets API service class SG/CD. The auto parts store is closer than the Cub Cadet dealer, and the oil was cheaper there so I bought 2 gallons of the oil at the auto parts store and a replacement Puralolator filter from TSC(cross referenced in the book at TSC).
Now that I've changed them, I seem to have air in the system. When I first ran the tractor and engaged the transmission, it was very noisy and hesitated to move the tractor. I checked the oil level and found that the oil had a lot of air bubbles in it. I figured I would be able to let the air work its way out of the system, so I let the oil in the reservoir clear up over the next few days and then ran it again. Same thing - air bubbles in the reservoir and a noisy transmission that hesitated to move the tractor. I repeated this process 3 or 4 times with no real change. This weekend, I needed to move the log splitter, so I got the tractor out. I could barely even back it up to the splitter. The transmission just would not engage and drive the tractor. I would push the pedal all the way down and nothing happened. The tractor just sat there. I couldn't hear any noises from the transmission at all. Finally after a few minutes of frustration, I got back on and held the pedal down to go forward. After about 30 seconds of just holding the pedal down, the transmission engaged and the tractor moved. I managed to get the log splitter hooked up and towed it to the back yard where I needed it. Unhooked the splitter and tried to drive away. Nothing doing. I could not get the transmission to engage. I ended up disengaging the transmission and pushing the tractor back to it's home in the garage.
Help! Is there an air bleed on the transmission I should use? The manual didn't say anything about bleeding the system in the transmission filter change instructions. Did I use the wrong oil and/or filter?
/ 2165 hydrostatic prob #2
A typical air-bleed procedure for a hydrostatic drive is to open the bypass (pull the free-wheel mode lever), start the tractor and cycle the F and R pedals a few times. This is supposed to work out the air. The only other thing I can think of is the filter? Maybe that filter is blocking flow somehow? I know you have to be real careful not to knock any crud into the hydo when pulling the filter or dipstick. Stuff can get in there real easy. That's a 3rd possibilty. Foreign material in there.
Joel
Thanks JTKub,
I just tried the bleed procedure you suggested. I ran the tractor for about 5 minutes with the transmission disengaged and kept cycling back and forth between forward and reverse. The pump engaged once for about 5 seconds or so while I was in forward, until I switched back to reverse - then it was gone again. At the end of the 5 minutes, I still can't drive the tractor. The oil in the reservoir is bubbly again though. Do I go for another 5-10 minutes, or does that risk damaging the pump?
/ 2165 hydrostatic prob #4
I'd think the bypass bleed should do it's thing in a matter of seconds. This is puzzling!?! If my memory serves me correct, there was an owner that had a similar issue that was fixed by trying a different hydro filter. He had an off brand on there, threw on an OEM and all was well. Dunno why, but it worked.
Joel
/ 2165 hydrostatic prob #6
I use a Carquest # 85410 (wix) filter for the trans on my 2544. It is a HD hydraulic filter. It's been in there for ~60hrs without issue. Thing is- it's just as expensive as a dealer filter. Is it any better? I have no idea.
Joel
/ 2165 hydrostatic prob #7
That the bleed down procedure has been done, I would also start diagnosing this problem by by purchasing and installing a Cub filter. It just sounds like the fluid isn't getting past the filter that is on there, and it's just getting whipped into bubbles by the pump.
-Fordlords-
/ 2165 hydrostatic prob #8
I thought I saw another thread here that said that some filters that appear to be direct replacements for the OEM ones have internal check valves that will defeat the hydro. Definitely install a CC filter.
It's on my to-do list for today. I'll report back here with my results.
/ 2165 hydrostatic prob #10
Here are the specs on the carquest/wix that I am running: Part Detail
Note: no bypass. Even if a filter were to bypass, you'd never know it.
G/luck
Joel
/ 2165 hydrostatic prob #11
You say that the manual lists 20W50 motor oil as a substitute for the Hydro oil. I'm a little leery of using motor oil for hydraulic systems. I used HyTran in my old 1450 and the newer synthetic Drive System Plus in my 3235. I've read other posts here about using motor oil but to me it always seemed to have a much different vicosity than hydraulic oil. If all else fails you might want to consider flushing out the motor oil and replacing it with the correct hydraulic oil.
Just my two cents.
Bob B.
Problem solved. I got a CC filter today and put it on. Within a few seconds of the bleed procedure described to me yesterday, everything was back to normal again.
FWIW, the filter I had on there that didn't work was a Purolator Premium Plus L14670. The next time around, I'll give the Wix filter a shot. I've never heard of them, so I'll have to find a dealer around here. $13 for a CC filter seems a little steep to me - although I suppose it could be much worse.
Thanks for all the help!
/ 2165 hydrostatic prob #13
It might be a steep price but look what you spent on time with trouble and the other filter!
/ 2165 hydrostatic prob #14
As the fluid and filters on these hydros don't have to be changed that often, going cheapo is NOT the way to go.
I don't think investing $50 total every 2-3 years (Fluid, filter, and gasket) for the awesome maintainable Cub Cadet hydros is a big deal at all for a unit that will give you everything you ask of it and last you and probably your siblings lifetime if you pass the machine on. Get the good stuff, that being the RIGHT stuff.
-Fordlords-
/ 2165 hydrostatic prob #15
I bought 3 or 4 genuine Cub Cadet transmission filters at Lowes this summer for $5 plus apiece. I thought they were unloading them because they dropped the CC line so I bought all they had. The last time in the store I noticed that they have more in stock.
Bob B.
/ 2165 hydrostatic prob #16
First of all, I realize this thread is several years old but it pertains to my question. I also have a 2165 CC and I need to change the hydro oil. To the author of the thread, have you noticed any adverse effects from running 20w50 oil instead of the CC OE oil? I'm considering doing the same instead of buying the CC oil at $15 per quart. Anyone else that can offer any advice is welcome to chime in also.
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2019 DODGE RAM 1500 (A65643)
2019 DODGE RAM...
Tenant T17 (A64127)
Tenant T17 (A64127)
