2160 will not crank
/ 2160 will not crank #1
2ndWind
I have a 1994 model 2160ags. It only has 175 hours on it. The starter went bad. I replaced it and it ran fine. It cut off one day while mowing an incline. When I tried to restart, i could hear the starter engage, but the engine would not crank. I took the started back off and noticed that I could not move the flywheel at all. It is locked, and will not move. I even tried a few light raps with a hammer on the back of a large screwdriver. It is solid. Any hope? Any suggestions?
/ 2160 will not crank #2
pull the engine plug(s) and then see if engine flywheel will turn by hand. Be careful of raw fuel being expelled out the plug hole(s). If raw fuel present, fix carb and then try to start. If flywheel still froze, time to have engine pulled/repaired/replaced.
/ 2160 will not crank #3
ALSO CHECK PTO IF BEARING IS TIED UP.
Update.
Checked both suggestions, still would not crank, as if engine had seized. Pulled engine, getting ready to tear it down. As a last ditch effort, I used a towel and a pair of channel lock pliers on the shaft and applied as much torque as I could. With a big sucking sound, everything broke free. Only guess is that being on the incline caused all the oil to flow to one side and maybe a valve got stuck. Although I had good levels and no indications of low pressure. Going to drain and replace all fluids while engine is out. Will update once reinstalled.
/ 2160 will not crank #5
Pull the rocker covers off the heads and ceck your valve/rocker activity.. I've seen heard about problems with these in other posts. Good luck!
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
1996 International 4700 (A64126)
1996 International...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
