2160 Leaking drive fluid
   / 2160 Leaking drive fluid #11
tnpnt1 said:
I have a AGS2160 that is leaking drive fluid out of the rear breather tube when I am mowing.Any ideas what would cause this? The fluid level is normal.
Thanks,John
Did this happen out of the blue or after a servicing, trans oil change, etc?? Your auto-gear transaxle (the "AG" part in AGS2160) is an odd duck. I have no idea how they work. I know they hold oil, have replaceable clutch packs and have the spin-on oil filter, but they are not hydrostatic or 'hydraulic' in any way that I know of. They must have some type of gearotor pump in them however to circulate the oil through the filter. If you just did an oil/filter change on it, I'd guess it's overfull. It's a good idea to add the exact same amount you dump out.
Joel
   / 2160 Leaking drive fluid #12
Can't help the original poster, but the AGS transaxle doesn't have a spin-on filter, at least mine doesn't (early serial number).
Thanks guys,but the problem was that the original dipstick was made too short so the transaxel was acutually over full.The replacement dipstick is about 1/2" longer.(but ofcourse this replacement is on backorder)
Ford 8510 (A53317)
Ford 8510 (A53317)
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
flooring (A55758)
flooring (A55758)
2020 MACK P164T (A58214)
2020 MACK P164T...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
