2160 Cub cuts out after 45min
   / 2160 Cub cuts out after 45min #1
Hillfarmer
West Virginia
Kubota B2630
A friend has a 5 year old cub 2160 mower that runs fine for about 45 minutes and then starts sputtering and eventually quits. After cooling for about and hour you can mow for another 45 minutes. Have had it to the mechanic and the points, plugs, fuel filter, and coil have been replaced. Please help.
   / 2160 Cub cuts out after 45min #2
Maybe clogged fuel cap vent. Next time it quits loosen cap and see if it sucks air into the tank.
   / 2160 Cub cuts out after 45min #3
I don't think those things have POINTS.. Next time it quits check spark-- If spark, give it a little shot of starting fluid or a lil gas in the carb and try it to determine your problem..
   / 2160 Cub cuts out after 45min #4
Flat or slope when quits?
   / 2160 Cub cuts out after 45min #5
ditto those comments. And - as it's an older machine - would pull the engine shroud sheet metal, clean the fins well & closely inspect revealed wiring insulation.
Sorry reply took so long, but I have been given the tractor to try to determine the problem. I checked the fuel cap and it vents fine.
The tractor does it on any terrain but if it starts and you turn the mower off it wil idle normally. If the pot is re-engaged it will start sputtering again.
I will need to investigate the wiring possibility.
Auger Drill Bit (A56857)
Auger Drill Bit...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
2001 Ford F-550 (A56858)
2001 Ford F-550...
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
2020 TAKEUCHI TB260 EXCAVATOR (A52709)
2020 TAKEUCHI...
golf cart (A55758)
golf cart (A55758)
