2155 leak
   / 2155 leak #1
red44
Hi folks. Newbie here. I have a minor issue that rears it's head every winter and I'm wondering if there's a fix. On our 2155 there is a shaft that runs through the "body", it is what the two arms of the 3 pt hitch attaches to. The shaft has seals at the body, but every winter these seals leak out most of the hydralic fluid. I've replaced these seals a few times, but I guess they are temp sensitive? They don't leak a drop spring thru fall. Any better options? Thanks.
   / 2155 leak #2
Welcome to TBN:D
I helped friend fix this very same problem on his machine (unsure of the model number). I only have two thoughts:
1-You are damaging the seals when you are installing them, it's a tight fit to get them in there. I boiled them in water to soften them, then folded them into a W shape to insert them.
2-The shaft is slightly worn where the seal contacts-you might need to mic the shaft when it's removed.
   / 2155 leak #3
I agree with kennyd. The shaft may be worn and also the bushings that the seals go into may be worn. How long since you replaced the seals? There was a batch of these that did leak in cold weather a few years ago. The new seals are now blue in color and made from a different material. They are much better than the old amber colored ones.
   / 2155 leak
Thanks. I have'nt replaced them in a couple-3 years. At least now I have a clue. :thumbsup:
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
SKID STEER SCARIFIER ATTACHMENT (A53843)
SKID STEER...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2015 TEXAS PRIDE TRAILER (A53843)
2015 TEXAS PRIDE...
