214ws or 14t baler
   / 214ws or 14t baler #1
donais
ramona ca
mf 1547
which one (if both work properly) would y'all get. same price when calculated for the exter gas to get the 214ws
   / 214ws or 14t baler #2
Are you looking for an antique (214ws) or a full use baler? The 14T was a popular baler. I don't know if parts availabilty is any good with those evil metal scrappers out there. A 24T is probably the best under $500 buy around.
   / 214ws or 14t baler #3
Which one would I get NOT EITHER ONE OF THEM!!!!!
There was a big difference between the two balers. There are not many 14t's out there still worth having. There are a fair number of parts still available for the 14t. Knottter parts easy to get, springs, bushings usually. Castings and wear plates not so much. As referenced they are steel slides. That was fine when they were new, but that was 50 years ago. The 214ws is a wire tie baler I do believe. Have you priced wire or wire substitute, if not, it will cure you of that question. It is really expensive. 24t was not a bad baler at all IF it was kept inside and taken care of. 214t was the heavy version of the 24t, and the fore runner to the 336. 214t has plunger on bearings and had a hydraulic thrower, #30, great baler if you can get one. If you keep your eyes open you may be able to find a real bargin on a 336. The last one I bought I paid 1000 for, spent 4 days in the shop doing the plunger and knotter and a few other things. In the last 4 years ran about 75K through it. There is nothing on a 336 that is not rebuildable, and parts are easy to come by. If you are doing a fair amount (over 500 a year) spend the extra and find a 336 if you can. You wont be sorry in the long run.
so i followed everyones advice! i bought the 214t baler. i figger with only 6 acres to bale it would be a good starter. ill jump in the boiling pot with that frog. now it came with sisal. should i stay with that or switch to poly? i don't know if i really care witch i use but hear the sisal rots quickly. how fast is quick? i was thinking of rebaling some straw to make them smaller and lets face it i need to learn how to use this thing. so any other advice? keep in mind i have a "real" job ant this adventure is to fulfill a lifelong dream. oh and for every bale i make that baler gets that much cheaper haha.. jon
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
CAT Skid Steer (A50322)
CAT Skid Steer...
2008 Caterpillar 345D Hydraulic Excavator (A50322)
2008 Caterpillar...
John Deere 6175M (A50120)
John Deere 6175M...
