2135 Cub Cadet saga
   / 2135 Cub Cadet saga #1
Greg-M
NE Ohio
- thanks to those posting some wiring diagrams!-
This tractor isn't mine, but in a manner of speaking I was asked to fix it. Mmm, OK. I didn't know much about it. It was supposed to have run and cut grass.
Previous owner and the second owner did some wiring "alterations". Hot wired and installed a separate switch for the PTO elec clutch. But it wouldn't stay engaged. Bad battery. Swapped in the proper one and got the clutch working-still w/ added switch, and grass cut. Until I went to shut it down. Wouldn't shut off. -gasp-
Stripped almost every connection, except for the battery terminals, still running. Found an ignition Hot and grounded it and it shut down. Shade-treed a new ignition switch. Same result.
Pulled all the added junk and U-Haul connectors wiring, and meanwhile looked at all the fuses. This is important later. Still the orig. PTO switch isn't turning on the PTO. But I did find that if I put the ign. key at the Lights position and got off the seat it would shut down.
Somewhere in its life someone had borked the headlights a little. After blowing the grass and grease and crud out of every nook and cranny I noticed some goofy wiring at the lights. One light was intact, the other had the wires ripped out _and_ someone had twisted both wires together. Ah geez. Pulled those apart.
I also finally noticed today that the hourmeter hadn't rolled over. The 30 amp fuse someone had slipped in was burned out, I just didn't pull it out and look at it. I ***-umed it wasn't burned looking like an auto application would be.
So-o I put a new fuse in it and everything is cherry. I was getting ready to do the tree diagram diagnosis which fortunately I had downloaded this morning, but all is well. Good ole girl.
Thanks to the folks here at TractorbyNet. :) Thanks
17201 (A55852)
17201 (A55852)
White Metal Roof Panels (A55758)
White Metal Roof...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2017 Ford F-550 (A55973)
2017 Ford F-550...
