2120 slow shift to reverse
   / 2120 slow shift to reverse #1
Lowrider2120
North Idaho
Kioti ck3510HST SE Cab, Kubota BX1500D
My '95 2120 w/2450 hrs has been gradually over the summer taking longer and longer for the shuttle shift to shift from forward to reverse. It now barely shifts into reverse. Filter was changed about 100 hrs ago and hyd levels are proper. The loader and other implements work fine. I'm guessing there is a valve somewhere that is sticking and not allowing proper shift.
Any thoughts??
   / 2120 slow shift to reverse #2
Have you checked the mechanical linkage inside the column sheet metal? If worn it could limit travel of the lever. Cheaper than hydraulics!
Jim
My son checked the switches but I'm not sure about the linkage itself...I will ask. Tractor is 40 miles away in field.
Thanks for the tip!
Jim
My son checked switches...not sure about linkage...I'll ask.
Thanks for the tip!
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
QUICK ATTACH SKID STEER HITCH (A57193)
QUICK ATTACH SKID...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
