2120 slow shift to reverse
   / 2120 slow shift to reverse #1
Lowrider2120
North Idaho
Kioti ck3510HST SE Cab, Kubota BX1500D
My '95 2120 w/2450 hrs has been gradually over the summer taking longer and longer for the shuttle shift to shift from forward to reverse. It now barely shifts into reverse. Filter was changed about 100 hrs ago and hyd levels are proper. The loader and other implements work fine. I'm guessing there is a valve somewhere that is sticking and not allowing proper shift.
Any thoughts??
   / 2120 slow shift to reverse #2
Have you checked the mechanical linkage inside the column sheet metal? If worn it could limit travel of the lever. Cheaper than hydraulics!
Jim
My son checked the switches but I'm not sure about the linkage itself...I will ask. Tractor is 40 miles away in field.
Thanks for the tip!
Jim
My son checked switches...not sure about linkage...I'll ask.
Thanks for the tip!
10 Bale Hay Graplle (A56469)
10 Bale Hay...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2024 Deere 335P (A53317)
2024 Deere 335P...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A55853)
2009 Skeeter SL190...
