2120 Shuttle Shift question
   / 2120 Shuttle Shift question #1
finspop
Hi,
I have a new-to-me 2120 with the HSS transmission. When parked in gear on a slope, the tractor rolls as if it were in neutral or the clutch pedal were depressed. Otherwise, it operates as normal, with no signs of slipping, chattering, etc, even under hard use.
Any ideas? thanks!
   / 2120 Shuttle Shift question #2
finspop said:
Hi,
Any ideas? thanks!
If you mean parked not running with the shuttle in F or R and both range and gear levers not in neutral, that's perfectly normal. The HSS drives through one of two hydraulic clutches (F or R) and either require hydraulic pressure and flow for lockup. Set the brakes before dismounting every time.
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
UNUSED WOLVERINE TL-12-72W - 72" HYD TILLER (A51248)
UNUSED WOLVERINE...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
