2120 pto safety switch
   / 2120 pto safety switch #1
audiski86
Salem, Connecticut
1997 New Holland 2120
I sometimes have to play around with the pto lever to get the tractor to start, but now I can't get it to go. Where is this switch and how can I bypass it. As usual this could not have happened at a worse time. I really need to move the tractor.
I still would like to know about the safety switch, but I have a different problem. Whats funny was that the tractor started and ran for 15 min before I turned it off. 10 min later it wouldn't start. I hooked up jumper cables to a dodge ram, and a vw jetta tdi, neither of which could start it but both did allow the fan to start turning momentarily. How big of a machine do i need to jump this? or might it be something else. One other time it was dead and I got an old gas JD 2010 to jump it.
   / 2120 pto safety switch #3
Have you tried cleaning conections at the battery , did you check the ground . How old is the battery ? If the battery is bad / shorted you may not be able to jump start it .
   / 2120 pto safety switch #4
I can't remember if it is the same but on my 1920 there is a safety switch that goes into the top of the transmission case right under the seat. In order for me to change it I had to un bolt the seat and remove it. I just can't remember if it was the pto but I think it was. I also do not know if it is the same as what you have on your 2120.
   / 2120 pto safety switch #5
There are two wires that go into a switch in the same area of the lever shaft that goes into the rear casting. This is the pto safety switch. I don't remember if it is NO or NC to start, but just try either way.
Look on the New hollamd web site under parts to view the location of the swith is this is not clear enough.
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2017 JOHN DEERE CP690 LOT IDENTIFIER 180 (A53084)
2017 JOHN DEERE...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
(APPROX 60) DIAMOND TREAD DBL AXLE FENDER BACKS (A51247)
(APPROX 60)...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
