2120 HSS command will not engage forward or reverse
   / 2120 HSS command will not engage forward or reverse
Well, I received the I&T manual today. Its worthless regarding the HSS with the electronic F/R shifter. It doesn't have it in there at all, and the pressure test directions are not applicable either because it relys on the manual control valve being engaged in reverse and forward, which this tractor does not have. On another note, Happy New Years!
   / 2120 HSS command will not engage forward or reverse #12
John, send me a PM with your email. I'll have to figure out how to send the pages - they're too big a file size for TBN. Jim
Jim, I sent you a PM. Thanks a bunch! John
Thanks to Jim's help I was able to test the control box. I have no voltage coming out on terminals 1 or 5 which tell the forward and reverse solenoids to engage. The manual says to replace the control box. It appeared someone in the past had attempted to open it. I finished the process, ignoring the "never remove this label" warning. Here is what I found. The diode I took a pic of is bad according to my dmm diode test. I can't find this specific diode online, if anyone knows anything about it please fill me in. I did find a very similar one in a spare samurai ecu made by hitachi. I've attached a pic of it also. Hopefully I can swap them and fins out if it works. The control box is made by Mitsubishi, and under the never remove label were numbers 385870680 and F8T71272 and 5Y27.
It worked! I took the old diode out (3rd picture). And replaced it with the one from the samurai ecu. I just "unsoldered" both diodes, and soldered in the "new" one. I went and installed the box in the tractor and all is well. I'm still going to try to find that exact diode. It has four little black dots on it. The samurai one did not. The control box costs $560 at the dealer. Helping a friend and fixing something the service manual says to just replace is priceless. Thanks again Jim, wouldn't have known for sure it was in the box without your help.
   / 2120 HSS command will not engage forward or reverse #16
Hey, good news. Might be useful to someone else too.
Jim
   / 2120 HSS command will not engage forward or reverse #17
Did you ever figure out any info on that diode? I have the exact same issue on my 2120. when I opened the control box that diode is pretty corroded. see attached pic. Diode.jpeg I suppose the other question would be is there a good source for reman control boxes? The dealer near me wants $650 for a new one...
   / 2120 HSS command will not engage forward or reverse #18
I have the same issue with a ford 2120 the diode is bad in the HSS system, does anybody know where you can buy the diode instead of the entire HSS unit
If you take the diode to an electronics shop they can probably identity it. Or go buy the ECU out of a samurai at a junkyard. That one I put in is still working.
I'm not sure where the pictures I had posted a while back went, but they showed the new diode.
Prime 604 (A53317)
Prime 604 (A53317)
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
2016 Chevrolet Express Enclosed Forensics Van (A55852)
2016 Chevrolet...
BED FROM 2024 FORD F250 SUPER DUTY (A57880)
BED FROM 2024 FORD...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2020 Chevrolet...
