2110 hyd.screen reinstall
/ 2110 hyd.screen reinstall #1
roadbuilder
Southwestern Oregon
Ford 2110 4x4, loader, implements
Hi,
We are ready to reinstall the plate/screen on our 2110 4x4 after cleaning the screen. I can't find anything on whether to install the gasket dry or if I should use a sealer or adhesive. I would assume that since it should be cleaned every 300 hours, I should leave it dry, or add a film of oil?. Thanks, Dale
/ 2110 hyd.screen reinstall #2
Hi,
Is that a ford 2110? I did not use anything on the paper gasket. The old one was a bit oily though.a tiny bit of RTV blue can't hurt if you want to keep the gasket steady from sliding around.
JC,
Yes, a '86 Ford 2110, with loader and assorted attachments. I applied a thin film of oil to gasket (both sides), and installed. No leaks anywhere. Thanks for the response though. I tried to get an intro out earlier and post a question, but as I have dial-up, I kept getting kicked off line. So I went on with the project and while we were waiting for the oil to drain, I decided to try my 1st post while at Dad's.
Dale
/ 2110 hyd.screen reinstall #4
Good deal Dale, oil film would not hurt the gasket at all. Dial up makes checking this forum a bit troublesome due to the volume of pics posted here.
JC,
PS. I don't know how close you are to Medford. South West Oregon gotta be a pretty neat place to live.
About 3 hours away JC. I live 15 miles east of Coos Bay at a little place called Allegany. I did live in Ashland for a couple years while going to SOSC. The Ashland/Medford area is my "2nd home", though we don't get down there much.
Dale
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
2011 Ford Explorer 4X4 SUV (A64557)
2011 Ford Explorer...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
