20x20 Carport Installation on 2x2x6 Concrete Blocks
   / 20x20 Carport Installation on 2x2x6 Concrete Blocks #1
ChrisGS
Deutz Fahr 5080D
Has anyone ever installed a carport of any size on these 2'x2'x6' concrete blocks or of similar size? If so, how did you mount the carport to the blocks? At auction, I got 3 carports and want to go this route for the added height and stability.
Any pictures or videos would be appreciated!
   / 20x20 Carport Installation on 2x2x6 Concrete Blocks #4
I helped anchor a 15x20 foot by 7 foot tall or so on pavers to increase the height. Used tap cons and it has withstood several winters and high winds but it is a bit protected between buildings fairly close by.
   / 20x20 Carport Installation on 2x2x6 Concrete Blocks #5
If you put it up on 2ft blocks, can you still open a car/truck door?
Bruce
   / 20x20 Carport Installation on 2x2x6 Concrete Blocks #6
Many years ago i put 6x6x8 concrete blocks (open in the middle)on level ground and 4x4 treated on top. Drilled the wood and hammered 2' rods thru the wood to the ground. This "foundation" still good
   / 20x20 Carport Installation on 2x2x6 Concrete Blocks #7
World block makes the forms for those blocks.
They're about 3,500-3,800lb each.
Drill and set anchors as if you are bolting it to a slab.
Before setting the blocks in place prep the ground so they don't settle. They are heavy enough to tear up stuff if they settle.
I didn't mount a carport to them, but have 20 of them doing different tasks at my place.
   / 20x20 Carport Installation on 2x2x6 Concrete Blocks #8
My steel carports are anchored to the ground with 3’ earth anchors at each corner, then 3’ rebar nails along the base channel. If you’re in a windy area it takes a lot to keep these anchored.
City of Lakeland (A51691)
City of Lakeland...
Commercial Trailer (A51692)
Commercial Trailer...
1998 Cornhusker Hopper Bottom Trailer (A50514)
1998 Cornhusker...
2007 John Deere CT332 Skidloader (RIDE AND DRIVE) (A50774)
2007 John Deere...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F450...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
