2082 and Kubota D722
   / 2082 and Kubota D722 #11
I would like to know how the D722 works for you in the 2082. I've got a 1782 and have often thought of putting a bigger Kubota in it. Kind of seems a little under powered but it is ok. If anyone is interested in a 1782 I would sell mine. I've spent several thousand dollars on it, engine re-ringed, power steering pump fixed(leaked), hydrostat rebuilt, new fenders, new hood, countless hours just tinkering. Have a 60 inch deck, 54 inch deck(bought new 2 years ago), front blade(weights chains). Have bought numerous other new parts. Looks good, almost new and it should for what I have spent on it. Anyway good luck on the engine swap.
   / 2082 and Kubota D722 #12
Don't think a D722 will fit in a 2082. If it does it will be real tight fit. The D640/D600 that cub Cadet used was a different family engine than the D722. The D722 is a bigger engine size wise. I put a D902 (That is the same family as the D640/D600) in a 1782 and and it was real tight. Had to use an electric fan because the Radiator was right next to the water pump. Good luck
2020 DRAGON ESP...
Brother CS6000i Computerized Sewing Machine (A54816)
Brother CS6000i...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
