2040 PTO clutch engagement
   / 2040 PTO clutch engagement #1
AmericanTractorDriver
USA
None
Hello,
I have a new-to-me 2040 (late 70's model). With the clutch pedal fully depressed, at times it's still very difficult to engage the PTO as there is intense vibration in the PTO lever when I try to engage it, almost as if the PTO clutch isn't fully releasing. I'll check tomorrow to see if there's an adjustment that may further separate the clutch. Otherwise is some amount of vibration in the lever normal? Not sure if it's related but a tiller we had attached which did not vibrate on a smaller tractor does vibrate as i Rev the engine up through mid-range and then smooths out at actual PTO speed.
Separate question, is there a reason it seems most finish mowers are 5-6'? This tractor has 40 PTO HP so I would think pulling an 8-10' finish mower on short turf would be quite doable.
Thanks!
   / 2040 PTO clutch engagement #2
Check clutch pedal free travel. It's possible pto clutch is warped or PP is rusty. When moving pto control lever forward on LH side one is engaging splines.
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
TEXAS PRIDE TRAILER (A53843)
TEXAS PRIDE...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
