2032R Rated PTO Speed and Rated Economy PTO Speed Lit
   / 2032R Rated PTO Speed and Rated Economy PTO Speed Lit #1
RSidetrack
John Deere 2032R
All,
I have an interesting situation with my 2019 2032R. Both the Rated Economy PTO Speed and the Rated PTO Speed lights are lit on the instrument cluster.
Now I will admit I don't know if the Rated PTO Speed was always lit and I got used to it, but what triggered my attention was the Rated Economy PTO Speed indicator is lit. In the manual it says that this isn't used, but darned if it isn't lit up.
When reading the manual I see the Rated PTO Speed indicator is mentioned for using the rear PTO, but I have the lever set to Mid PTO only. I have tried moving it all the way to rear only and back to mid only and the lights are still lit.
So I am not sure if something is going on which is causing both lights to light up, in which case what would trigger this, or if I have some sort of glitch happening.
It is under warranty, but figured I would reach out here first to see if anyone has any thoughts before I run down that avenue.
Thanks!
   / 2032R Rated PTO Speed and Rated Economy PTO Speed Lit #2
Maybe it's just the limit switches on the levers that are getting stuck. It can happens some times with moisture and dust.
That's a good thought. I haven't done my Spring Cleaning of the tractor yet so will see if I can manage to find and check/clean them while doing so.
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
