2030 Hydraulic Noise
   / 2030 Hydraulic Noise #1
jhertenstein
Flora, IL
John Deere 2030
Hello all,
I have a 70's vintage 2030. I recently had to have the brake pads replaced because they were deteriorating and plugging up the hydraulic intake. Now I'm hearing a new noise that seems to be coming from the hydraulic pump. This is confirmed by actuating one of the loader valves which changes or eliminates the noise. Is the pump bad? There doesn't seem to be any loss in hydraulic power.
As a separate issue both the loader and the three point will "drift" lower even with the tractor running at a high RPM. What causes this effect?
Thanks in advance for your support.
Hertenstein
   / 2030 Hydraulic Noise #2
1st thing I suggest to check is condition of frt hyd pump drive coupler. Moving of hyd components such as 3 pt or loader while control isn't actuated could indicate leaking cyl seals or internal leaking control valve
Thanks. The control valve is pretty noise and makes a high pitched "hissing" sound which I assume is fluid leaking through.
2013 INTERNATIONAL REEFER TRUCK (A53426)
2013 INTERNATIONAL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
John Deere 5075E (A50123)
John Deere 5075E...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
John Deere 648G2 Grapple Skidder (A52384)
John Deere 648G2...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
