2030 died while driving, now struggles to start
   / 2030 died while driving, now struggles to start #1
tbndt2030
UK
John Deere 2030, 1975
Hi,
I have a 1975 diesel 2030, bought a few months ago. The temperature gauge doesn't work.
Was out topping yesterday for a couple of hours when I noticed a lot of white smoke from the exhaust, then it just died under me. There seemed to be some smoke coming from underneath too, I think from on the sump, so I think it was hot and burning some of the oil that covers the underneath.
I let it cool for 10 mins or so and tried to restart it, and it wouldn't turn over. Just a solitary "chung" when I turned the starter.
Left it alone for an hour or two and went back. This time it seemed to put a little more effort in when turning the starter, and after a few goes it came to life, and I got it back down the field, but it died again at the bottom. An hour or so later it still felt hot to the touch, so I left it overnight.
This morning it seemed to labour on turnover, but did eventually come to life. To get it to go I had to hold the starter on for longer than normal, though, and it didn't seem to rev as much as I would expect for throttle positions.
Anyway, managed to get it back into the barn. What next? I would suspect battery issues for the starting trouble, but that wouldn't (TTBOMK) cause it to die while running.
   / 2030 died while driving, now struggles to start #2
Sounds like you are going to need a major overhaul now.
   / 2030 died while driving, now struggles to start #3
Sounds to me like it is getting hot and seizing. Any coolant in the radiator? Water pump working? Fan belt loose?
There is coolant. I started it up again in the barn. It ran for couple of minutes then I thought about opening radiator cap -- it was bubbling vigorously already. So I guess something isn't cooling properly.
   / 2030 died while driving, now struggles to start #5
White smoke indicates unburnt fuel or coolant. Coolant will have a sweet smell, unburnt fuel will of course smell like diesel. Did you notice either before it shut down?
I didn't think to explicitly consider it, but the barn mostly smelt like diesel fumes; I think a sweet smell would have been unexpected and therefore perhaps I would have noticed.
Edit: I haven't changed the coolant, so there's the chance that it was cheaply filled with too much water and wouldn't smell, I suppose.
   / 2030 died while driving, now struggles to start #7
I'll suggest to install an operating coolant temp gauge. With engine cold & running, rad cap removed can you see any bubbles in coolant in rad neck? Can you detect any coolant in engine crankcase?
   / 2030 died while driving, now struggles to start #8
I think it's calling for a new head gasket. Bubbles in rad, hard or no crank, dying after running some time, these are indicators for a failed head gasket.
Make sure Collingwood system is working properly and overheating wasn't the reason for the gasket to go.
Collingwood system?
Edit: oh, I'm going to guess something autocorrected "cooling" :)
   / 2030 died while driving, now struggles to start #10
It should mean cooling system and not Collingwood. Darn phone.
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53473)
2019 Energreen EVO...
1994 Ford F-350 Emergency Truck (A51692)
1994 Ford F-350...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
