2025r SCV valve suddenly stiff
   / 2025r SCV valve suddenly stiff #1
furnone
Trumbull, CT
2018 JD 2025R, 2004 John Deere 2210
2019 2025r. The SCV valve for the raise and lower function is suddenly very stiff. It loosens a little as it warms up, but is still stiffer than normal. The curl function has the normal resistance.
It feels like maybe an o-ring that has swelled or gotten out of a groove. I tried spraying with dry lube.
Looks like a lot of parts in there, should I attempt to open it up and try to diagnose, or leave it to the pros? Or just leave it as long as it keeps working?
   / 2025r SCV valve suddenly stiff #2
Is the valve direct operated by joystick or via a cable? If cable they have been known to go bad. If exposed linkage between joystick and valve I would check for something binding.
Joystick
   / 2025r SCV valve suddenly stiff #4
Since direct mount joystick would point towards a problem in the centering spring and detent assembly located at the other end of the valve. Only other thing is if some foreign particle got caught between the spool and valve housing since the only O-rings are on each of the spool to keep oil from spilling on the ground.
2012 Ford F-250 Pickup Truck, VIN # 1FT7W2B69CEB80936 (A57453)
2012 Ford F-250...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
UNITED 5' BOX BLADE (A52708)
UNITED 5' BOX...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
CASE IH 496 DISC HARROW (A52708)
CASE IH 496 DISC...
1607 (A57192)
1607 (A57192)
