Snow 2025r radial tire chains
   / 2025r radial tire chains #1
rlcowder
I have a 2018 2025r with the new R3 radial tires size 280/70 R16. I need some tire chains but I cannot find any manufacturer that has them for that size tire. My local dealer has come up with nothing as well. Anyone out there know of a supplier? I messaged several online chain makers and none of them can even make me a set until spring. Any help is appreciated.
Tread pattern
   / 2025r radial tire chains #4
Made my own for the 4300. Calculated the length of the side chains, and the length of the cross chains. Bought the two different chain lengths and the connector parts needed.. and got what I wanted..
The WESTWARD pliers look like they would be very helpful if making your own, or modifying some existing chains.
   / 2025r radial tire chains #5
Tread pattern
Not a tire expert but the sae equivalent should be a 31x11. Deere p/n pm2229r chains out of their light truck section show fitting a 31x11.5-16. I think as well that the 280/70r16 is only an inch taller than a 245/75r16. May or may not be helpful.
Finally got a good cross reference set of chains.
Deere part PM3229R Model TCB10915
   / 2025r radial tire chains #7
Did that set of chains work for you and fit good?
2014 Lamar Trailers 45ft T/A Pipe Handling Trailer (A55973)
2014 Lamar...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
