2025: Year of the Tick
   / 2025: Year of the Tick #91
Permethrin is definitely the best thing I've found. I spray my work pants with a 12% solution. I've read that that mix will prevent ticks from being attracted, and is supposed to be good for 75 washings. I have my doubts about that so I spray them at least every other use.
Sitting on a tailgate taking a break, I've seen ticks walking up my pant legs and then fall off. I liberally coat my pants with this stuff and have been using it for going on for over 10 years now.
For the edge of yards and around the base of foundations (mostly to kill mosquitos since I do own swampland), I use a Stihl fogger with a Tengard SFR 36.8% Permethrin Insecticide mixed up with water.
https://www.amazon.com/dp/B003ORU2PO?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
   / 2025: Year of the Tick #92
I heard Mike mention once on Outdoors with the Morgans Youtube channel that he has often been asked why he wears light colored, khaki style pants to work in (I'm thinking like Dickies brand) - he mentioned that with blue denim you can't see the ticks as readily as on khaki colored pants.
Seems like a good idea. When I move out to our new Merryvale property I think I'm going to change up my wardrobe a bit. Besides that, between the copperheads, timber rattlers, and cottonmouths, probably going to need snake chaps too from what I've heard.
At my previous 20 acre property in Ohio, we had ~60 free range chickens. No tick issues at all. However, they caused some neighbor issues.
   / 2025: Year of the Tick #93
I have the same yellow bottle and it's what I use on my shoes and pants and hat.
   / 2025: Year of the Tick #94
I use permethrin Which is why I find them vs. remove them.
But yesterday I was just walking along the driveway, open area, slightly overhung with branches. Did not expect one to drop out of the tall brush. I was feet away from any foliage.
When I go into the woods I wear a treated hat.
Seems I need to walk in the center of the driveway this year
We have a local plant called "tick weed". There's something about the plant that attracts ticks this time of year, so the plant is just shimmering with ticks on every stem. If you accidentally brush a branch your sleeve or pants leg is suddenly swarming with ticks. I have never seen anything like it, and yes, I stay a good yard away from the plant at all times because it does feel as if ticks jump off of it. 😱
@Santa Craig Cringle don't forget "snake proof" boots in your new wardrobe.
All the best,
Peter
   / 2025: Year of the Tick #96
Can they really bite thru a good leather athletic shoe?
Based on what I have seen them bite through, yes, I think, no problem. A friend was bitten through a pair of heavy leather pull on boots (3/32" thick +/-, thick, rather like "biker" boots). Most of the venom ended up pooled on his sock, but the skin was scratched, so off to the hospital he went. He was a skilled marksman, was carrying at the time, and shot it dead, so there wasn't any question about the kind of snake.
My personal takeaway was that bulk and distance from the skin is important in addition to boot toughness.
As all of this happened during high temperatures, the other takeaway is that knowing that one is living in snake country, be aware at all times. They can't "see" you well when it is hot nor when they are shedding. Look over logs/obstacles before stepping over, look on rocks, watch for those cottonmouths around water always, and if you smell cucumber, stop.
All the best,
Peter
   / 2025: Year of the Tick #97
Cucumber? You can tell that I don't live in snake country. ;)
   / 2025: Year of the Tick #98
All the best,
Peter
Need to Plant that in Clumps, then Spark it up. A little "Controlled Burn" But the "Huggers" would disagree.
   / 2025: Year of the Tick #99
Apparently it is specific to cottonmouths.
Unfortunately, not a warning smell for the other American vipers...
   / 2025: Year of the Tick #100
Second stop of the day, in the town where I got the tick which put me on antibiotics 2 months ago.
As I sat here eating lunch and reading this thread I reached up and scratched my neck; pulling a tick off which had just started to attach itself.
I haven't even gotten out of the truck!!!
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
New/Unused Grapple for CFG Mini Excavator (A54865)
New/Unused Grapple...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
