2024 vs 2025 CX2510HCB
/ 2024 vs 2025 CX2510HCB #1
Ira
Bronze Member
Just found out that the two CX2510HCB's on the local dealer's lot are 2024 models. Saw it on the quote sheet but dealer never mentioned it. Both of them are new.
Are there any differences between the two years? I don't know where to find any info/specs on the 2024 to compare against the 2025.
Should I expect the dealer to discount the 2024 model a little more than if it was a 2025?
/ 2024 vs 2025 CX2510HCB #2
There is no difference between the 2024 and 2025; you may get a little more off the 2024 to get it off the lot, but no guarantee.
/ 2024 vs 2025 CX2510HCB #3
They are the same tractor. Please consider that it is usually 3-5 months between the time the tractor is manufactured until it is available to be delivered to a dealer lot. Most of the time, everything we have on the lot until April - June, will have a previous year serial number. The dealer may not have had the tractors for as long as it may seem from the serial numbers.
Hope this helps
Thanks for the info. My only concern was that I might be missing some good enhancements available on 2025 models. The dealer said both tractors were delivered to them a few weeks ago.
/ 2024 vs 2025 CX2510HCB #5
There wouldn't be any enhancements. Kioti doesn't do model years. They do series. Ex..CK2610 vs CK2620. When they make a change or enhancement they upgrade the series number. (the CK2620 came out in 2023, so there would be no difference between it and a brand new one off the boat.)
I understand the confusion... you've been conditioned by modern automobiles. What you heard Tacticalturnip and Michiganiron say was 'the 2024 and the 2025 Kioti units are the same'. But what they meant was 'They are literally built the same way as they were last year'
Which makes sense because the used tractor world doesn't really care about +1 or -1 year, we are more concerned with + or - the number of hours.
