2023 50 hour service
   / 2023 50 hour service #21
Theres a sticky post at the beginning of the LS forum that has all the filter/oil info.
I just did the 50hr service on my R4041H, a little over $110 for (6) WIX filters, change engine oil to 5W-40 for winter, and top off about a gallon of hydro oil lost when filters were pulled.
Total as a DIY was under $200.
My 50 hour service may have been overkill but was recommended by dealer to minimize LS Factory warranty problems down the road- He seemed to imply that he and I would have greater leverage re warranty work if all fluids and filters were completely changed at 50 hours- He continued to say that he and LS did not foresee any need to change all fluids for a long long long time based on my residential use and factory requirements. considering the extra labor and Hydro fluid required I don't consider $390 high.
I changed my own engine oil and filter, $13 for the oil and $8 for the filter. So another $21 on top of my $140 for a full service.
   / 2023 50 hour service #23
What all is the dealer going to do besides change the oil. I have about 21 hours on my 3038H and I'm trying decide if I need to drag it to the dealer for the 50 hr or if I can just do it myself.
Thx
JW
Thx
JW
Depends on if your tractor is a hydrostat. Mine was 2 hydro filters and 5 gallons of hydro oil. It should say specifically in your manual.
Geared tractors would probably just be engine oil and filter.
   / 2023 50 hour service #25
My R4041 Hydro was just all filters. (two hydro, one engine, one fuel, and two air filters)
I changed the engine oil, all filters, and topped off the hydro oil (loses about a gallon when filters are removed).
Took a little over an hour.
   / 2023 50 hour service #26
My R4041 Hydro was just all filters. (two hydro, one engine, one fuel, and two air filters) I changed the engine oil, all filters, and topped off the hydro oil (loses about a gallon when filters are removed). Took a little over an hour.
I think changing air filters and fuel filters at 50 hours is a waste of good money.
   / 2023 50 hour service #27
Yea at 50 hrs probably, but I had them and its done.
I bought the tractor used with 58hrs on it so I thought it best to do them all while I was at it.
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Hose Reel (A55787)
Hose Reel (A55787)
2020 MACK P164T (A58214)
2020 MACK P164T...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
