2023 50 hour service
   / 2023 50 hour service
My 2023 has filled rear tires as per dealer recommendation- I think LS or your dealer is giving you the run around- Ballast on a tractor with loader is industry standard as Guesseral has said above. BTW My tractor is in right now for service and one of my issues is the rear diff. doesn't seem to be working-- we'll see what my guys say. Good Luck
Can you PM me with info on what dealer has your tractor? My dealer said that LS told them my tractor is the first they've heard of a having a rear diff problem. If I had the info, I can give it to my dealer and tell them mine is certainly not the only one with the problem.
Look in your owners manual and see if the manual states to install liquid ballast to off set the weight in the loader. I assume that you have a loader, then they can't blame it on you because you did what the manual said.
Look at the website under specifications it states weight without ballast! I really don't think there should be any problem here with the ballasted tires.
You know, I don't know if the manual says anything about fluid in the tires but I'll check. I know there are a lot of members here that have filled their LS tractor tires so I'm definitely not the only one.
   / 2023 50 hour service #13
PM'ed you- Not certain my 2023 has a diff issue- just asked dealer to check it out-
   / 2023 50 hour service #15
In the owner's manual, does LS recommend a Ballast Box instead of filled rear tires?
   / 2023 50 hour service #16
I haven't looked at the manual but the label on my loader shows a warning about it.
   / 2023 50 hour service #17
It clearly states in the loader manual to Add rear tire liquid weight for Counterweight.
That's good to know. I haven't had time to get my manuals out yet. I haven't heard from the dealer yet either.
Forgot to update my thread, but the dealer did the 50 hour service, but only changed the 2 hydro filters and refilled with hydro oil. $140
My manual says to only change the engine oil filter at 50 hours, but NOT the actual oil. Anyone know the oil filters for the J2023?
   / 2023 50 hour service #20
My 50 hour service may have been overkill but was recommended by dealer to minimize LS Factory warranty problems down the road- He seemed to imply that he and I would have greater leverage re warranty work if all fluids and filters were completely changed at 50 hours- He continued to say that he and LS did not foresee any need to change all fluids for a long long long time based on my residential use and factory requirements. considering the extra labor and Hydro fluid required I don't consider $390 high.
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
