2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #11
Wow is it ugly! Close tie with the current GM trucks. Ugh!
I think the designers of ALL the FS trucks go to the same school of butt ugly.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #12
There have been quite a few defects and problems with the 2022 models -- best to wait until they iron out the problems.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #13
Can you explain? Where are they having problems? I just replaced a 2007 Tundra with a 2018. Not sold on the looks of the 2022. Also nt sure of the new engine setup. Just wondering. Jon.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #14
There have been a few new Tundras with turbo wastegate issues requiring removal of the cab to reach the turbo on the back of the engine. It’s not just old Ford 6.0/6.4 diesel guys with their trucks in the shop with the cabs removed anymore. Not a good look for Toyota.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #15
There is just something wrong in truck design if you have to remove the truck cab to remove a turbo from an engine. I think designers and engineers have a little too much faith in the reliability of their components.
Just mount the front clip and cab on a subframe with hydraulics so you can just tilt it up out of the way like a cabover semi tractor.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #16
It has been said before but I think designers and engineers should be MADE to work on anything they design before it could be sold. Bet if that happened you would have access/room to work without having to strip half the vehicle to work on it.
I'm an engineer and I approve of this message.
it might have been just an urban legend back then but it was reported that to change the rearward sparkplugs on a big block Mustang, you had to loosen the engine.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #19
That's good advice regarding the launch of any new vehicle. 👍
I can't say anything about the trucks comfort or capabilities, but I can see a 2022 Tundra in my neighbors driveway and it's... unfortunate looking.
   / 2022 Toyota Tundra 1794 Edition: Everything’s Bigger in Texas #20
I’m in the market for a new truck and waited for the reveal of the new Tundra before placing an order. IMO, Toyota missed the mark in a few areas on the new Tundra. 1) Disappointingly low payload (1450lbs on a crew cab Limited), 2) no flat floor under the back seat, 3) no step to make bed access easier, 4) turbo on back of engine making servicing a PITA, 5) hybrid version has giant heavy battery under rear seat reducing storage and payload.
I ordered a Ford F-350 Tremor instead for not much more than the cost of a new Tundra.
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
