2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
Item Details
Listing Type
Auction
Stock ID
57024
Make
Brushwolf
Type
Ag Equip
Year
2022
Seller
Fastline Auction, LLC
Model
4800FX
North Carolina
Description: The Brush Wolf 4800X is a 48-inch brush cutter attachment for excavators and backhoes. This model is ideal for clearing trails, ditches, and hillsides. Performance specifications: Maximum cutting diameter: The cutter can handle saplings and brush up to 4 inches thick. Cutting width: The cutting path is 48 inches wide. Hydraulic flow: The cutter requires 16 to 25 GPM of auxiliary hydraulic flow. Tip speed: 7,500 to 18,400 feet per minute. Operating PSI: 3,000 continuous / 3,500 intermittent. Blades: The unit uses two 0.5-inch by 4-inch high-strength updraft blades. Blade carrier: The blades are mounted on a 1-inch GRD-50 disc. Blade rotation: The blades rotate counterclockwise when viewed from above. Design and build: Weight: 880 pounds (excluding the hanger). Overall length: 62.80 inches. Overall width: 51.13 inches. Deck thickness: 7 gauge (0.188 inches). Motor/drive: An Eaton Geroler-style hydraulic motor powers a right-angle gearbox. Drive protection: Features a GRD-2 shear bolt to protect the drive components. Motor protection: Pressure relief valves protect the motor from pressure spikes. Warranty: Comes with a three-year structural steel warranty. Year: 2022 Make: Brushwolf Model: 4800X - SF Serial No.: 1721 Stock No.: A0315 FASTLINE SALES REPRESENTATIVE(s) Bobby Kennerson bobby.kennerson@fastline.com 502-222-8303 Item Location - Address: Provided by Seller Item Location - City: Franklinville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 27248 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 2500.00 USD
Auction Finishes: November 11, 2025 at 07:14 PM
Click Here To Bid Now!
Happy Bidding!
UNUSED IRANCH IRTPL 10000Ib TWO-POST CAR LIFT (A60432)
UNUSED IRANCH...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
(APPROX.15) 5/8"-4'X8' OSB (A60432)
(APPROX.15)...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
FUEL CELL (A58214)
FUEL CELL (A58214)
