2020
   / 2020 #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
Need information on 2020. Good, Bad, parts available? How does the shift work on it? I think it's a 3 cylinder motor. Any information would be helpful. Thanks!!!
   / 2020 #2
Good tractor. Parts not as prevailant as the 00 series, simply because they are a newer model. Give them time, some day the YMXX00 models will run out and you will see more later models. The shifter of the YM2020 as well as all the 20 series is located below the steering column. You can shifter from neutral to reverse or any forward gear with or without clutching. And yes it is a 3 cylinder engine.
2019 CATERPILLAR 279D SKID STEER (A50458)
2019 CATERPILLAR...
(INOP) JCB 930 ROUGH TERRAIN FORKLIFT (A50459)
(INOP) JCB 930...
UNUSED MOWERKING SKID STEER PALLET FORKS (A50460)
UNUSED MOWERKING...
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2017 MAHINDRA MAX26XL TRACTOR (A50459)
2017 MAHINDRA...
SKID STEER QUICK ATTACH PALLET FORKS W/ 48" FORKS (A50460)
SKID STEER QUICK...
