2020 T394 engine knocking noise
   / 2020 T394 engine knocking noise
That would be GOOD news, AND a plus having such a good dealer.
Absolutely! Scott's recreation went from 1 dealer to 2 since i bought my tractor and they're opening 2 more in New England. They're doing something right I'd say. It's nice to have a dealer on your side that's for sure.
update: dealer called and told me they can't duplicate the noise. When It started up to be driven off the trailer once I got it to the dealers I couldn't hear it and I thought " how typical". The mechanic starts it multiple times a day and varies the rpms and hears nothing. he checked the injector lines for tightness and is continuing a search for "suction side air leaks". I am very happy for the update but mystified why this phenomenon occurs. things always run fine when you bring it to the shop.:unsure:
Fixed:
They found a metal broken cross member under the motor that would slap against the engine at certain RPM's. I can't believe i missed during my many searches. I'm really happy with the dealer and relieved it wasn't anything major.
Final update:
The rattle was caused by the front driveshaft Shroud not a crossmember. There is only a tiny spot weld that broke from vibration. They said it was only to keep grass from getting tangled around the drive shaft so i opted to keep it off.
12 Yard Rolloff Container (A51573)
12 Yard Rolloff...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
New Holland 55 Pull Type Rake (A51573)
New Holland 55...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
