2020 reverser
/ 2020 reverser #1
RdPhil
Case
I have a 2020 JD and it won't go into forward some times but when it does it seems to hold good till I go to reverse and back agin. Can anyone help
/ 2020 reverser #2
First things to check are trans oil level, trans filter and the internal filter screen.
/ 2020 reverser #3
I agree what Zebrafive stated plus checking shift valve pressures plus looking at shift linkage for wear.
/ 2020 reverser
The filter us new and I followed pressures and it's low on the forward side of the valve under the right step and reverse pressure is up does that indicate bad valve spool or seals or forward clutch pack
/ 2020 reverser #5
The down side to a hyd reverser is there are many places that can cause low pressure. The control valve spools or gaskets could be leaking or the clutch pack seals. I suggest you purchase a "Technical Manual CD-ROM TM1044CD 2020 Tractor" if you don't already have one.
/ 2020 reverser
Thank you Jim I have a manual and it gets me to checking pressures but not the main cause of the low pressure so I guess I'm going with the least costly and labor intensive first being the control valve on the outside of tractor
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
2015 Ram 4500 Service Truck, VIN # 3C7WRKAJ9FG707673 (A65563)
2015 Ram 4500...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
Cattle Feeder (A65640)
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Dodge 4500 Bucket Truck (A63689)
Dodge 4500 Bucket...
