202 engine - conrod bolt weakness?
   / 202 engine - conrod bolt weakness? #1
Jdswede
Uppsala, Sweden
John Deere JD400 1968
I am not sure but I think I have 202 engine in my JD 400 backhoe. When I bought, it one of the connecting rod bolts had become loose and was resting in the oil tray.
A while ago I read at a Swedish forum that conrod bolts is a known issue in the 202 engines. Does anyone know if there is any substance in this rumour?
   / 202 engine - conrod bolt weakness? #2
Can't speak to the issue but general practice is to not re-use con rod bolts.
   / 202 engine - conrod bolt weakness? #3
I don't remember 202 cid engines having conn rod bolt problems when I was employed by JD dealer from '66-'87
Thanks for your input!
The bolt was still in one piece but the theads were slightly damaged.
I do not know anything about the history of the engine. If it was rebuilt they may have missed to tighten the bolt properly or reused an old bolt. I now have to get a new connecting rod (and new bolts!). The crankshaft was also damaged.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51247)
KNOW BEFORE YOU...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
