Loader 2019 Massey 1526
   / 2019 Massey 1526 #1
minnesota774
Massey Ferguson 1526
I recently sold my 1948 8N and bought a 2019 Massey 1526 with a loader and blower. I have noticed that there is about a million times more online information and a thousand more places for 8N parts than for the Massey. Guess that is the downside of a new tractor.
The sales literature all showed an L100E loader and mine came with an FLx 2106. I am looking to add either a third function or a hydraulic diverter to run a grapple. I have found some good diverters online. However, Massey sells a third function kit for the 1700E series, not one for the 1526. Does anybody know how easy it might be to jerry-rig it to work on the 1526?
I plan on throwing some lights and a toolbox on the ROPS (without drilling or cutting). Just gotta find a good spot to wire into! Thanks!
   / 2019 Massey 1526 #2
Looks like the FLX 2106 is a new loader for the 1526 and 3rd function is an option through Massey. I have no experience with this I have just been looking at the Massey 1526 and found that info on their website.
   / 2019 Massey 1526 #3
I tried to post the copy and paste from Massey's website but my post count is too low.
   / 2019 Massey 1526 #4
I'll try to post again.
   / 2019 Massey 1526 #5
I found this on the Massey Ferguson website:
Implements
Sub-Compact & Compact Loaders
Common Standard Features
One-piece curved boom design with tapered arms and single cross tube
Quick-connect hydraulic lines
Positive locking galvanized steel bushings at all pivot points to minimize wear
Recessed grease zerks to minimize accidental damage
Hydraulic lines routed inside loader frame for protection and visibility
Built-in parking stands
Industry leading cycle times for performance and efficiency
Regenerative hydraulics for simultaneous operation of Lift/lower and curl/dump functions
Skid steer coupler standard and pin-type option on FLx2106 and FLx2407 models
Optional 3rd function & SoftDrive loader suspension available on all models
Specifications
Model Lift Height @ Pivot Pin in. (mm) Lift Capacity to Max. Height @ Pivot Pin lbs (kg) Breakout Force at 500mm Pivot Pin lbs (kg) Compatible Tractor Models
FL1805 74 (1,880) 922 (418) 980 (450) GC1700
FLx2106 83 (2,110) 1,270 (576) 1,330 (600) 1526
FLx2407 94 (2,390) 1,450 (659) 1.560 (710) 1700E
FL2611 100 (2,550) 1,870 (848) 2,170 (980) 1735M, 1740M
FL2814 111 (2,830) 2,570 (1,166) 2,960 (1,340) 1750M, 1755M, 1760M
   / 2019 Massey 1526 #6
   / 2019 Massey 1526 #7
I'm trying to do the same thing on my 1526 with an L100E Loader. I looked up the loaders that the Diverted Valve fits and compared the connectors to those on the L100E and they are the same part numbers, so it should fit. The lack of info is shocking. You could try the same thing (I used the parts lookup on Vahrenberg's site. The Dealer also said I could bring the tractor up and swap out the lines to make sure they fit. Good luck!
   / 2019 Massey 1526 #8
Hello...I have a 2019, MF1526...now have 300 hrs on it....I have a fire extinguisher attached to the inside, right hand side of the ROPS attached with a wire flat clamp and the bottom rest on the fender, rubber separates the extinguisher. from the plastic fender and then on the opposite ROPS ( left side/ inside , I have a metal ammunition can attached with a U bolt going around the ROPS and through the can.
   / 2019 Massey 1526 #9
I don't have an MF 1526 but I do have a 1529 and so I thought I would share what I found when I wanted to power some electronics on my tractor. Hopefully yours isn't that much different.
In the attached photo, you will see the multi-pin connector near the left side of the ROPS on my 1529. If your 1526 also has this plug, you should be able to use it assuming you don't draw excessive current. If you also have this plug, your owner's manual should show it on the electrical diagram and you can see what it is fused/rated for.
   / 2019 Massey 1526 #10
Hello...the 1526 also has the trailer plug on the left side along with a wire (live) on the left side and one on the right side under/near the fender. you will need to ground the light(s). Both are on their own fuse... My ROPS lights are connected to the power on the right side rear and you will need it switched as it is live power.
20711 (A50323)
20711 (A50323)
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
