2019 L6060 Regens
   / 2019 L6060 Regens #11
I know a lot of people think it's always cold in Canada but it does get hot here too. Since I bought the tractor the ambient temps have been around 80 to 90 degrees F. So if I only get 15 hrs between regents at that temp what will it be like when the temps drop to 0 degrees F.
I really don't have any concerns with the regen process. Just curious to see what others are expiencing. I will just keep using it as required and keep an eye on it. So far I love this tractor.
I'm in Colorado. Not Canada cold but I do a bit of plowing in the negatives (Freedom units). I havent noticed any real difference between the winter or pushing triple diget summers regen wise.
   / 2019 L6060 Regens #12
I have a M7060 and had (4) regens so far. I have not run the tractor hard as I was still under the 50 hour break in.
1st 17 hours
2nd 30.5 hours
3rd 44.3 hours
4th 57 hours
   / 2019 L6060 Regens
Thanks guys.
Looks like mine is acting normal. I also found another thread where this was brought up and lots of guys are getting 12 to 13 hrs between regens.
   / 2019 L6060 Regens
Funny thing just happened. I was hauling bucket loads of gravel down my driveway to do some minor work on one spot and noticed the soot level went from 1% at the beginning to 6% close to the end. During that time I was running down in high range, rabbit and back up in high range turtle, trying not to work the tractor too hard yet. Still only has 40 hrs on it and the driveway is quite steep. Average grade between the gravel pile and the work area is about 10% with a few spots that are about 15%. The distance from tgrabel pile to work area is about 3/4 mile. So on the last trip up the driveway I ran in high range, rabbit at 2000rpm and watched the soot level start at 7% then drop to 6% when I got to the top.
It's all a learning experience.
   / 2019 L6060 Regens #15
Modern engines don't require a detailed break in. Work the snot out of it. Don't over heat it. It's a tractor.
   / 2019 L6060 Regens #16
I don’t think my L6060 has done a regen at less than 25 hours but I rarely run less than 2000 rpm except at warmup. Seeing the DPF% go down under low is not uncommon - like dropping from 70% to 60% in 20 minutes of very high load. The M135GX I once had also dropped % under heavy load but the M7-171 that replaced it has never dropped. So don’t be surprised to see your DPF % drop as much as 10% without doing a regen.
   / 2019 L6060 Regens #17
I was wondering, to those who have more regens for not using the tractors hard enough, if one of those additives made for DPFs could help those situations? And maybe prevent DPF clogging in the future.
I read on a German Branson forum, where a tractor owner had nice results with the CRC DPF Cleaner on his tractor.
   / 2019 L6060 Regens #18
1st 17 hours
2nd 30.5 hours
3rd 44.3 hours
4th 57 hours
I have about 80 hours on my 7060 and I believe mine has had 6 regens. That's a combination of snowblowing, road grading, mowing, and misc. loader work.
I try to run at least 2000 rpm or pto rpm. Seems like a lot to me.
   / 2019 L6060 Regens #19
I checked last night, I'm right at 37 hours and my regen screen shows 99%. So, my guess is this weekend I will do my 1st regen.
   / 2019 L6060 Regens
Looks like this is all over the map. 17hrs to 37hrs between regens. From my vast experience so far (40hrs :) and what I've read here it appears that running the engine at high rpms does not seem to help much, if at all. But working the engine does. Makes sense but on the other hand with my older diesels they would smoke like crazy when they were worked hard and no smoke when they were just cruising.
My tractor will not likely experience much hard work during it's life. Mostly loader work, some minor grass mowing, a little light brush cutting, post hole auger work, box blading the driveway and using the snowblower. The blower might work the engine some but only if I use it on the 3PTH where I can use all of the hp. If I use the blower on the FEL with the rear hydraulic power pack the tractor will not likely experience much load. The hydraulic motor is only rated for 25hp and will go into relief if it gets loaded too much. The only things that will work the tractor hard is plowing snow when going uphill or running up the driveway in high range, rabbit. I guess my tractor will go through a lot of regens. Glad its not a big deal and only takes about 10 mins (well so far anyways).
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
SKID STEER GRAPPLE BUCKET (A58214)
SKID STEER GRAPPLE...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
