2019-2020 Ram CP-4 pump replacement
   / 2019-2020 Ram CP-4 pump replacement #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
I am one of the “lucky” owners of a ‘19 or ‘20 Ram Cummins with the CP-4 pump. If you didn’t already know, these pumps are found in all 3 major brands of truck and across a few different models as well.
As far as I know, Ram was the only manufacturer to offer free replacement of all affected models.
Mine was done on Monday & Tuesday, absolutely free of charge. I have read the replacement cost per truck cost Stellantis about $8,000 per truck! Ram did the right thing for its’ customers.
Truck feels basically the same. Start times are just slightly longer than with the CP-4. Could be air working it’s way out. Interesting that the CP-4 actually developed higher rail/injector pressures than the CP-3.
Read about the whole thing here. Pretty interesting read. Looks like Ford & GM have yet to step up to the plate despite lawsuits.
   / 2019-2020 Ram CP-4 pump replacement #2
GM completely abandoned Bosch, went with Denso. Bosch is part of the problem, zero help from them.
Ram is far from perfect, a friend has 2 19 Ram hd with the CP4, but because they are not listed in that, they are Customer Pay.
Maybe they did, but if you read the article, GM stuck customers with failed pumps, so did Ford.
Tell your friend the 2019 Ram is listed to be factory repaired at no cost to him/her/
   / 2019-2020 Ram CP-4 pump replacement #4
His is outside the specified models, he has already gone above the dealer to corporate. Not all 2019's are covered.
The blame goes on the EPA/CARB, the CP4 was not designed to run on our ULSD.
The models affected are…
  • 2019 to 2020 Ram 2500 (DJ) – 113,720 units built between October 11th, 2018 to November 13th, 2020.
  • 2019 to 2020 Ram 3500 (D2) – 67,586 units built between October 18th, 2018 to November 13th, 2020.
  • 2019 to 2020 Ram 3500 Chassis Cab (DD) – 11,384 units built between November 29th, 2018 to November 13th, 2020.
  • 2019 to 2020 Ram 4500/5500 Chassis Cab (DP) – 29,720 units built between November 29th, 2018 to November 13th, 2020
Well, that sucks. Why would they maroon a few 2019 owners…
But at least Ram covered most trucks.
   / 2019-2020 Ram CP-4 pump replacement #6
Hay , was your transmission recalled ?
   / 2019-2020 Ram CP-4 pump replacement #8
Recall came about because someone with a lot of brains sued as a safety issue, when it grenades loss of power steering brakes etc. The government got involved case closed. That is how I understand it
I am still a Cummins fan
   / 2019-2020 Ram CP-4 pump replacement #9
There was a recall mine was done a year or two ago for tranny not too much to it, they did when double deep mag tec was installed
   / 2019-2020 Ram CP-4 pump replacement #10
Some had an issue with fluid overflowing and causing a fire.
JOHN DEERE 6615D MFWD TRACTOR (A52708)
JOHN DEERE 6615D...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
HARDEE SH-360-CO 5' DITCH BANK CUTTER (A52708)
HARDEE SH-360-CO...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
