Security & Theft 2018 EMAX 22s
/ 2018 EMAX 22s #1
mcleod9
Mahindra emax 22s
I want to make sure no one can hot wire my Emax 22S and steal it. I don't want to have to remove the battery after each use. Is there a single fuse I can pull to prevent it from starting? Surely someone has had the same problem. I've read that there is a 40 amp fuse somewhere but can't find it. Not in the fuse panel. Thanks
/ 2018 EMAX 22s #2
You might exploit one of the safety switches. On my previous tractor, I would engage the PTO lever which would prevent starting. There are other, sometimes more obscure, safety switches that could also be used or unplugged.
/ 2018 EMAX 22s
Thanks. I've considered hiding a toggle switch for the seat somewhere "obscure".
/ 2018 EMAX 22s #4
I had my dealer install a toggle switch when I bought it. Works great. I had to leave the tractor out in the open on a construction site for our new house for about 3 months until I could get the 2nd garage built. Let me sleep well at night.
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
121A (A63745)
121A (A63745)
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
