2018 2025R Glow Plugs
   / 2018 2025R Glow Plugs #1
jsb2b
Southern Tier, NY
JD 2025R (Gen 2)
I have a 2018 2025R that starts with a cloud of blue/white smoke and rough idles for about 5 seconds with one final puff of smoke. This started around 25 hours. I added Sea Foam figuring bad fuel or dirty injector but it still does it at 31 hours. I even cycled the ignition switch 3 times to get 15 seconds of glow plug heat. Not much difference. I want to test the 3 glow plugs but I'll be damned if I can get to the nut on top of each glow plug. Anyone have an idea or can post the service manual page? Much appreciated.
   / 2018 2025R Glow Plugs #2
Glow plugs? Are you sure, or do you have a heating intake element ?
Ok, looked at jdparts and you do have the glow plugs..
   / 2018 2025R Glow Plugs #3
•Glow plugs on the 2025R provide quick starts in temperatures down to 0° F. (Optional engine coolant heater attachment will assist starting under more extreme conditions.)
•Air intake heater cold starting aid on the 2032R provides quick starts in temperatures down to
2 Family Compact Utility Tractors | 225R | John Deere US
So the dealer picked up my 2018 2025R with 34 hours on it. He said that all new 1 series and 2 series smoke on cold startup. I can't believe this is "normal". I haven't seen any complaints on this forum. Does anyone here have a 1 series or 2 series that looks like a mosquito fogger for several seconds on cold (in 45 degree garage) start?????
   / 2018 2025R Glow Plugs #5
There are compliants on the G T T forum about it....
Welcome to teir 4 emissions.
   / 2018 2025R Glow Plugs #6
I've got about 6 hours on my 2025R and yes, it smokes for a few seconds on a cold start. Doesn't matter if I use the glow plugs or not. It starts easy enough though. I also notice a high idle speed, at little over 1500 rpm. I'm not sure if that is part of the emissions or because a 3 cylinder idles rough at a slower RPM.
Found the threads on GTT. Discouraging. The before Rom Flash and after Rom Flash videos of the startup smoke reduction were remarkable but that was a 1025 in 2013... Me thinks I'm going to see what the dealer comes up with...
   / 2018 2025R Glow Plugs #9
My GC Massey does the same thing, my 2305 and my neighbors 2305 does it also, it's normal..
These little tractors smoke a little un burnt fuel at startup, Indirect injected smoke a tad more than direct injected from my own personal experience with my own direct and indirect injected engines.
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
Aluminum Boat Top (A53117)
Aluminum Boat Top...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2020 Sellick S80 (A50123)
2020 Sellick S80...
