2017 CK3510 HST Wont Start
   / 2017 CK3510 HST Wont Start #1
KenGod
PA
CK2610HST
The tractor ran fine yesterday, Today it wont start.
When trying to start with the Ignition switch the lights on dash blink and showing error codes 006 and 008 with just a loud clicking noise.
When I jump the starter, small ignition switch wire to large terminal, the tractor starts and runs.
I just spent an hour searching the net for Kioti error codes, not one search result, Im amazed there is no list of error codes for Kioti tractors anywhere on the net.
Anyone have any ideas what's up?
Thank you,
   / 2017 CK3510 HST Wont Start #2
Loud clicking indicates not enough juice to the starter. Possibly the starter relay except with my experience if it's the relay there's no clicking. Poor connection some place is possible as well . A ground ?
Im getting 13.2 Volts while starting, Starts right up when jumping the starter solenoid, any idea what codes 006 and 008 are?
   / 2017 CK3510 HST Wont Start #4
I'm not familiar with codes. It's also possibly one of the safety features on the tractor or ? the ignition switch.
   / 2017 CK3510 HST Wont Start #5
my 2018 started doing the same thing, i checked and the brake light fuse was blown so i replaced it and as soon as i tried to start it the fuse blew, i then replaced the brake light relay and fuse and it started fine for a couple of weeks, today it started fine but now it won’t turn off, so i lugged it out and even with the key off and out of the ignition the dash lights and ac fan were still on until i disconnected the battery, any thoughts
   / 2017 CK3510 HST Wont Start #6
Quick question…has the warranty expired?
   / 2017 CK3510 HST Wont Start #7
Check the back of the ignition switch for any corrosion between the terminals.
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
